Sewing Machine: Needle won't move
A disengaged clutch, broken drive belt or internal drive gear failure can prevent the needle from moving. Engage the hand wheel clutch if you have it disengaged for bobbin winding. If the needle won't move with the clutch engaged, unplug the sewing machine and check the drive belt. https://www.searspartsdirect.com/diy/symptom/sewing-machine-repair/1234596/needle-won-t-move/smac1011147
How to Fix Brother Sewing Machine Error Code E6
Q: What does E6 error message mean?
A: The motor locked up because thread is tangled
Q: How to fix E6 error message?
A: Do the following:
The upper thread could be tangled. Remove the upper thread and any loose threads. Raise the pressure foot, raise the needle to its highest position and rethread the machine.
Remove the bobbin and bobbin case to clean any lint or loose threads. Install the bobbin case so that the projection on it aligns with the spring. Then install the bobbin into the bobbin case.
The needle could be bent. Replace the needle making sure the flat side is facing the back.
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
could also be a timing problem
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation. brother sewing machine
first change the needle rethread the machine top & bobbin use every thread guide clean under the needle plate & in the bobbin area for lint make sure the bobbin is not warped or damaged make sure the bobbin is not to full make sure the bobbin is inserted correctly & turned correctly in the bobbin case make sure there are not any burrs on the needle plate make sure there are not any burrs on the bobbin case
I would suggest rethreading the machine to make sure the thread is not caught somewhere, & even change the needle or check to make sure the needle is in correctly & pushed all the way up in the needle holder & if that doens't help then take it back to the repair shop & tell them about the problem
