Hi I have harwa TV it's saying it scann channels
Posted by Tracy on
Vernon Taylor
  • Televison & ... Master
  • 7,426 Answers
If it says scan channels then that is what you should do. Check the antenna connection if good and access the tv main menu and select either scan for channels or installation or factory reset. Often you will be required to enter a PIN to select major menu options.
Posted on Nov 30, 2020
2 Related Answers
Anonymous
SOURCE: harwa tv childlock code
Harwa password is 000000
Posted on Apr 07, 2009
Anonymous
For Harwa (also branded Logik) 54cm colour TV with remote RC-A07 showing blue screen with red lock in the corner, hold down "music" button on remote for 10 seconds to unlock.
Posted on May 31, 2009
I have a Bravia TV and have lost Channel 7
Ur tv is hook up to a antena and getting free AIR DTV broadcasting signal?Yes,tv have lost channel 7 tunning in frequencies.Go into ur tv menu goto SETUP and pick EZ or Wizard scannning might get it back,not must go into Ch. pick AIR not Cable to rescan the whole thing for picking up all free AIR DTV channels again.If tv it is getting pay Cable do the same thing,pick CABLE for channels scanning not AIR.
Apr 07, 2011 | Sony Televison & Video
How do you activate the tv to scann for channels?
Use the tv remote push the menu button go to SETUP,than go down to Ch.pick AIR or CABLE than enter for scranning for channels for pay CABLE or free AIR channels.
Mar 02, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
I have a Harwa t.v that wont change the channel, It can do everything else but is stuck on one channel. It wont even go on to a.v because it has a lock on it. How do I get the lock off if I dont even know...
you can fix this by resetting the television to factory default,
Forced to factory default: press and hold [VOLUME ( - )] on the TV and press [MENU] on the remote 2 seconds. Exit: Unplug Power to reset.
If it does not help, the main board need to replace.
Hope this will help...
Jun 14, 2010 | Televison & Video
How do a program or scann the channels in my sony bravia t.v?
If you're referring to the KDL-40V2500 TV, please refer to the page number 37 in the manual to Auto Program the TV.
Press the MENU button on the Remote. Then, select the ANALOG SETUP SETTINGS.
Then, select the AUTO PROGRAM under the ANALOG SETUP SETTINGS.
Jun 13, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
TV says "no signal"
my tv says no signal when the cable is plugged in and i have tried scannning it but it says no service found ... what can i do
Feb 16, 2009 | Vizio GV42L 42 in. LCD Television
Harwa tv childlock code
Nov 18, 2008 | Televison & Video
Oct 24, 2008 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
