This problem can come from both the blender and or even the circuit powering it. First make sure that the outlet you have your blender plugged into is powered and not ripped If your blender still is not turning on then you may have a faulty motor or motor connection. Or the fuse could be blown and needs to be replaced.Or it could also be jamming for this you must first need to disassemble the drive and then turn the blade shaft. If it seems to be stuck or jammed here check what is the causing it to be jamming. In most of the cases it is debris that are stuck in the blades of the blender that causes it to be stuck.
