Amazon Kindle Fire HD
Kate, The source, radio shack, computer repair store or even a friend that is some what knowledgeable about computers. Kate you can even google search (Amazon Kindle Fire battery replacement) and maybe do it yourself after watching video or reading guide. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Good Luck. How to Replace Your Amazon Kindle Fire Battery
Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
Step 2
Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
Step 3 - Battery
Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
step 4
Repeat the process from the previous step to free the left battery cell.
Step 5
Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
This is usually a sign of either a failing charger or Kindle, let's try to hard reset the Kindle. Step 1: Press and hold the power button for 60 seconds Step 2: Plug the Kindle into the changer, press and hold the power for 30 seconds Step 3: Let charge for 12 hours Step 4: Turn on and use the Kindle, if it shuts down before 6 to 8 hours of use, contact Amazon for a replacement.
If the kindle won't turn on because it was recently dropped or water was spilled on it or something, you should consult your warranty. If this is due to no external event/damage you should call amazon and see whether or not there's an update in software or a bug of sorts. If it's on their behalf you'll get a replacement device. Good luck!
