Question about Bose Audio Players & Recorders
How to convert Bose sa4 into analog input like sa3
Posted by Ganesh K on
HRHabib
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 73 Answers
Hi guys
I'm having quite a bit of trouble setting up my Soundtouch SA 4 AMP. I'm yet to do the IT course required to fix the issues with my music libraries not being found, but I'll get onto that when I have spare weekend to devote to tackling it.
In the meantime i am wondering if someone can tell me how to connect a device directly to it via the auxiliary input.
I was told by the reseller I purchased it off that I needed to use the aux port to connect my smart TV to the Soundtouch. However I can't find any mention of it in the manual or on the forums and have tried the headphone jack input but with no joy.
I also use this feature often as I have the Soundtouch set up in my entertaining area....inevitably people come over and politely inform me that my taste in music is a little on the nose - so they plug their iPhone into the system to show me how to do it right! Sadly that happens way too often (Abba- Bee Gee's - where am I going wrong?).
So please help - how do I connect audio devices directly into the Sountouch SA4 Amp without using Wi-Fi?
Thanks
Posted on Nov 29, 2020
2 Related Answers
Anonymous
  • 66 Answers
SOURCE: Bose SA3
while hooking up the RCA'S? I wouldnt think so
Posted on Dec 12, 2007
Anonymous
SOURCE: Best way to use US-Bose SA3 amp in Europe ?
Bose say you should pay to get it converted because over time the slightly different power cycles can effect it, however it will still works fine if you change the voltage with an adapter - like I did!!!
Posted on Jul 16, 2009
How to install a bose sa3 to a bose v35
How to install a bose sa3 to a bose v35....http://m.topix.com/forum/who/bose/TOH8RAETEKGB8966I/p2. See the link above . Sometimes audio cable quality n the ohm makes a difference . 12_27_2013_11_17_29_pm.png
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sam_bbe602d2c68da69b
Dec 12, 2013 | Audio Players & Recorders
Sa3 bose not sound from boselink but external input yes
It depends on the Bose system you connected with the amp and the type of Bose remote you are using?Does the indicator LED at the rear of the amplifier stay solid green when you press the ON button on the remote?If not,check that your room code setting on the remote correspond with the micro switches setting at the rear of your amplifier.
Feb 08, 2013 | Bose SA3
Bose sa3 amp, blew a fuse in it, replaced it and now it won't power up. Nice little amp, would like to find out how to test out what is wrong and fix it
If you can,check with your multimeter to see if the two voltage rectifiers are good.If they are OK,you may need to replace the 2 audio amplifiers.This will require proper tools and good experience.
Jan 06, 2013 | Bose SA3
How do I connect 2 jbl ct 26 speakers in a series to Bose sa3
I don't know the impedance of these speakers but the Bose SA3 amplifier is 100watts per channel.A higher wattage speaker may damage the audio amplifiers.
Aug 28, 2012 | Bose SA3
I have a Bose lifestyle 50 (from 1999) and just purchased a new Sony Bravia TV. How can I connect the TV to the Bose sound system?
hello!
unless your "Bose" has an optical or coaxial digital stream audio inputs, there is no way of connecting TVs audio output to your receiver(home theater). to by pass the TV itself, connect analog audio output off your cable or set top boxes. those, still have analog audio out. If you need to connect more audio sources, use TV as a video monitor, connect all the audio outs to your "Bose", instead. In case of terrestrial broadcast, you may need to obtain digital converter box and use it simultaneously with TV to get your audio out. Also, if you lack DVR, that box will allow you to use regular DVD recorder. It's not going to be HD quality, but better, than nothing. You can't feed HD video signal out of TV set.Only analog.
good luck,
Alex.
Feb 01, 2012 | Bose Audio Players & Recorders
SA3 amplifier to move to Europe : capability of the transformer ?
While living in the States I purchased a Bose Acoustimass 10 system but have now moved back to the UAE. As the system operates on 115 volts ONLY I would like to get it work on 240V without having to use a step-down transformer. By changing out the transformer form 115v to 240v will it work or will I have to change any other components within the system. Can anyone help me??
Dec 12, 2008 | Bose Lifestyle SA-3 2-Channel Amplifier
Bose SA3
Dec 12, 2007 | Audio Players & Recorders
15 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
