Question about Hisense Televison & Video
Hello, I have a Hisense 32h3e 120v 60hz 50w LED LCD tv. The indicator light is on when I plug it in (solid color, not flashing), but the screen remains blank when I hit the power button
Posted by Josh fry on
The jack of all trades
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 145 Answers
If the light stay solid red when our hit the power button then problem is in main board . If flashing it's in the power board . Easy thing to check first is a blown fuse they can blow simply by unplugging tv while tv is on
Posted on Nov 27, 2020
ray gallant
    Top Expert:
  • Hisense Master
  • 73,786 Answers
THINK REPAIR SHOP LOCALLY
5 Related Answers
Anonymous
SOURCE: Screen goes blank also.
The thing with removing the power from the back of the monitor and holding the Down Button down whilst plugging back in the power does work. My 19inch Monitor was having the same sort of problem. White lines would appear as I turned on the monitor. I did the hard reset on the monitor and it works! I was awed and amazed.
Posted on Nov 26, 2007
4me2no
SOURCE: 57xbr2....tv turns on briefly...solid color screen for a second...then blank?
I had the same problem about a 8 months ago. I searched online and found that there is a problem with one of the color guns. They need to be replaced. I don't remember where I found the information, but there is a number or something to call for this problem. I think that my authorized sony repair man knew of the problem, there are other models that have the same problem. Anyway, sony replaced all three guns in my tv FREE of charge, and my tv was no longer under warranty. They did all repairs and fixed my tv.
Posted on Jun 09, 2008
Anonymous
SOURCE: System won't power up
ITS BROKE - YOU HAVE TO GET IT FIXED OR THROW IT OUT. SAME THING HAPPENED TO US -UNDER WARRANTY BUT WE HAVE TO PAY THE $80 TO SHIP IT TO THEM. WHAT A FARSE.
Posted on Aug 29, 2008
Anonymous
SOURCE: TV won't turn off
Problem solved. I opened the configuration menu, went to Setup, More, Light Effect, changed setting from "Always" to "In Watching TV".
Posted on Dec 10, 2008
brianberbine
  • 3 Answers
SOURCE: proview pl716s monitor will not come on
i just had this problem with my screen (proview pl716s) if you open the case and take out the power board, there are 6 470 uf capasitors bundled together and 1 220uf capasitor replace all 7 and that should fix your problem , that is what i did and it worked like a charm , oh and btw make sure before you swap your monitor from an older standard monitor to the lcd make sure the resolution is high enough becuase if it is not then the monitor will not be able to be displayd , hope that helps
Posted on Jul 22, 2009
1helpful
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
There are universal power supply units available that come with a variety of interchangeable ends and switchable polarity, current and voltages. However, if one of these will fit your particular needs I have no idea or indeed if they are available in your country. Try eBay or Amazon. I hope that is of some help.
Im ulysees i have a Liquid Crystal Tv model# LC-70LE650U 120V~ 60Hz 228W when plugged in the screen dosent light up the bottom indicator light holds solid then starts to blink after about 15sec
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board [One see at the left side; Green coloured] is faulty.
Hisense tv flashing 6 red lights
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
My lcd tv the screen flashes like blinks when the background is a light color like an icesurface
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Hisense led tv has audio but no picture seen .
follow this instruction and fix it. God bless you
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
9helpful
4answers
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Televison & Video Logo
Top Hisense Televison & Video Experts
Jean Sintulaire
Ekse
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
