Hi! Please double check the manual https://documents.4rgos.it/v1/static/4237233_R_D001. If still didn't work, you can call the customer service of the product provider and have replacement if its still covered with the warranty.
WHY DON'T YOU ASK A LOCAL REPAIR SHOP
SOURCE: cleaning above the grill element
I would not advise you to remove the element unless you feel competent to do so.
Best thing to do is to put the grill full on and let all the fat and grease burn itself off.
you will not hurt anything by doing this.
Make sure you have the griil door open and your house door.
Plz rate my solution.
thanks.
SOURCE: oven element has small area that is glowing red
Hi, It is a bad element. There is also a change the element cause the switch to short out too.
Is this a top burner or the bake element?
If it glowing while the power is off at the switch, check and see if part of the element is grounding against the stove.
I hope this helps. Please let me know if I can assist you further.
Vic
SOURCE: fan and grill works, grill actually cooks but oven
Without a doubt this is the element that is faulty.
It is located at the rear of the inner oven compartment behind a removeable cover.
SOURCE: Hi there Have recently moved into
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
Testimonial: "Cheers, sounds good"
SOURCE: The oven heating element seems
If you can see the element heating up, but the fan is not working, then you need to replace the fan motor assy, if you do not, then the element is in danger of burning out.
