Question about Bryant Heating & Cooling
Where is the filter located? Bryant hvac fa4anf024
Posted by Barbara Riddle... on
ray gallant
    Top Expert:
  • Bryant Master
  • 74,122 Answers
USUALLY ON THE FRESH AIR INTAKE SIDE OF THE SYSTEM
Posted on Nov 25, 2020
Bryant HVAC, reads "system fault, 84 high pressure, lockout for 4)
It could be your filter is dirty or condenser is dirty.
2helpful
How to replace " cabin
The 2001 model Aztex has 2 cabin filters, they usually come 2 to a box when you buy them.
The charcoal carbon filters are the best.
Removal:
•Open the IP compartment door.
•Remove the rear inside IP compartment door.
•Open the HVAC module assembly access door
•Remove the RH passenger compartment air filter from the HVAC module.
•Slide the LH passenger compartment air filter to the HVAC module opening.
Remove the LH passenger compartment air filter from the HVAC module.
Installation Procedure:
•Install the LH passenger compartment air filter into the HVAC module opening.
Slide the LH passenger compartment air filter toward the left side of the HVAC module.
•Install the RH passenger compartment air filter into the HVAC module opening.
•Close the HVAC module assembly access door.
•Install the rear inside IP compartment door.
•Close the IP compartment door.
I Hope this information is helpful.
Dont know where air filter is located. model # 574ANW030060NA roof top
Most installers will put your filters in the ceiling return air grille. If not, you will more than likely have to get on the roof and remove a side panel. Hopefully it will say "filter access" on the side of the panel.
1helpful
Thanks for your answer, but I was asking about the cabin air filter not the engin air intake filter
The cabin air filter is usually located behind the glove box or at the base of the windshield in the cowl area over the HVAC inlet duct. The exact location can be found in the vehicle owner’s manual or a filter reference guide at the auto part store where you purchase the cabin air filter from.
On most Fords, the filter is located under the hood in the cowl area. On Chrysler models, it is located under the dash. On GM products, it might be under the hood (Impala, Lumina and Monte Carlo), under the dash (Avalanche, Silverado, Suburban and Tahoe) or behind the glove box (Venture). On Toyota, Lexus, Nissan and most Honda models, you’ll find the filter behind the glove box. There is no cabin air filter even listed for a 1998 Oldsmobile Regency.
On vehicles where the cabin air filter is mounted under the cowl at the base of the windshield, some disassembly may be required to replace the filter. This may involve removing a plastic cowl cover. The area around the filter usually collects debris, so this area should be cleaned to remove any leaves, bugs or other debris before the old filter is pulled out. This will prevent any contaminants from falling into the HVAC inlet duct.
On vehicles where the filter is located behind the glove box, the glove box may have to be removed to replace the filter. On others, the filter can be accessed from under the dash and pulled out of a slot in the HVAC unit.
Most cabin air filters are flat-panel filters, but some have unusual shapes, so they will fit the HVAC inlet duct. Some filters also come in two sections to make replacement easier.
Where i can found the ac filter, bacause i want to replace. tnks
AIR FILTER
DESCRIPTION
A dust and odor air filter is standard equipment on
models equipped with the three zone temperature
control systems. The filter element is the
same size as the front air conditioner evaporator to
ensure ample filtering capacity. A removable door on
the bottom of the front HVAC housing below the
glove box provides easy access to the filter element
for replacement. The filter should be checked and
replaced at least once every 24,000 km (15,000 miles)
and checked if heater-A/C system performance seems
lower than expected.
REMOVAL
(1) Locate the air filter door on the bottom of the
lower HVAC housing just outboard of the passenger
side of the instrument panel center stack.
(2) Slide the air filter door latch toward the rear of
the vehicle until it engages the opened stop on the
door.
(3) Pull the air filter door straight downward to
disengage it from the air filter opening of the lower
HVAC housing.
(4) Use your fingers to reach through the air filter
opening of the lower HVAC housing far enough to
grasp the air filter.
(5) Pull the air filter straight down and out of the
HVAC housing.
INSTALLATION
(1) Note the “Airflow” directional arrow imprinted
on the foam seal around the frame of the air filter.
This arrow should always be oriented towards the
center of the vehicle.
(2) With the air filter “Airflow” arrow properly oriented,
carefully slide the filter fully upward into the
HVAC housing through the air filter opening.
(3) With the latch still positioned against its
opened stop, reinstall the air filter door onto the
lower HVAC housing air filter opening.
(4) Slide the air filter door latch toward the front
of the vehicle until it hits the closed stop on the door.
Good luck
Uv needs to be replaced, where can pick one up and how much should it cost
You may find it on the web, but carrier/bryant is very strict on who sells their parts. You will have to find a local hvac contractor that is a dealer to purchase.
2answers
Filter for Bryant plus 90i
Bryant Furnace Filters www.iaqsource.com Every Bryant filter in stock For every Bryant furnace and AC
may want to check on the filter itself and the housing for numbers that could assist its type and size
this site may help you
2answers
Bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Heating & Cooling Logo
Top Bryant Heating & Cooling Experts
Dan Webster
Dan Webster
john h
Tom Chichester
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
