Question about Home
How to track a vessel efficiently? - Home
Posted by Julia S on
WATCHING YOU
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Home Master
  • 37,613 Answers
There are online websites that can do that if you know the name of the vessel
Posted on Nov 27, 2020
John Gibbert
You can use vessel data services provided by other companies. We use datalastic.com and take all data about vessels movements from there, it is an API which we connected to our ERP.
Vernon Taylor
  • 7,436 Answers
I am no expert on such matters but I hear it isn't easy even with modern radar and satellite observation though of course much depends on the size of the vessel, the construction and the range you wish to track it as well as whether you are fixed or mobile and your elevation.
The best way is to place a radio beacon aboard and have at least three listening stations equipped with direction-finding receiving equipment.
Posted on Nov 25, 2020
Main Reasons for Failures of Pressure Vessels?
Under the same circumstances, pressure vessels get higher failure rates than other equipment. Most pressure vessels generally withstand loads which is static and relatively steady. Thus, pressure vessels will not be broken due to the overuse like rotating machinery, and not be out of operation owing to the fatigue like high-speed engines.According to the research and practice, the reasons for pressure vessels' high failure rates are listed below.Pressure vessels have strict working conditions.Not only various loads of pressure (pulsatile pressure generally) do pressure vessels withstand, but also pressure vessels withstand some other loads. Moreover, pressure vessels, sometimes, need to be operated in cryogenic conditions or tough working environments with high temperatures or corrosive working media.Pressure vessels are overloaded easily.The pressure inside the pressure vessels usually rises due to the misoperation and the abnormal reaction. Besides, pressure vessels are always broken before the abnormal conditions are noticed.Pressure vessels has complex local stress. For example, the opening and the other discontinuous constructions of pressure vessels are always fractured by fatigue because of not only excessively high local stress but also continual loading and unloading.There are some hidden problems of pressure vessels.Welded or forged containers can easily get serious defects such as fine cracks in manufacture. These defects might become more serious in operation and make pressure vessels broken in certain conditions.Wrong Management of pressure vesselsPressure vessels are used illegally. In order to escape from supervision and management, some factories buy equipment produced by unauthorized and uncertified manufacturers and the equipment is used as pressure vessels, which can cause serious failures. Legal pressure vessels are operated without normative management.Enterprises have supervisory engineering staff without knowing professional knowledge and regulations of pressure vessels. Failures occur easily when pressure vessel operators do not have neither qualifications nor experience of professional training.There are no safety regulations for operations, technical documents of equipment, periodic inspections for equipment and qualified employees or management personnel.As a result, pressure vessels and their safety accessories, with abnormal use and disordered management, are not in safety management.Without authorization, pressure vessels are not only used in wrong conditions, but also even refitted. Managers of factories neglect the safety operation of pressure vessels and the pressure vessels are used in unsuitable working environments for adapting to certain processing technologies. Moreover, even some broken pressure vessels are also put into use. Thus, the wrong operation and the overuse of pressure vessels can result in serious problems.The local supervision department in charge of safety production, relevant administrative departments and relevant law enforce authorities do not work effectively and have not yet adapted to the progress of socialist market economy. The rapid increased quantity of small widespread private enterprises causes wrong operation, ******* equipment control and loose supervision of relevant departments.
http://www.dfctank.com/pressure-vessel.html
Nov 23, 2017 | The Computers & Internet
How long can I keep water in vessel?
Yes water can be stored for many days. Make sure if you are drinking this water that the vessel is sterile, clean and cover the water with a lid
Mar 04, 2015 | Bosch Tassimo T20 Single Serve Brewer,...
How to change vessel type on my FA150 shows wrong vessel type
This requires a secret dealer only pass word to enter the set up on the FA 150. Call me
847-746-0100, John Barry
May 28, 2014 | Furuno Boating
What is a decanter?
A decanter is a vessel that is used to allow the decantation of any liquid that has sediment-most often it will hold wine. When you pour the wine into the decanter, the sediment is left in the first vessel. As well, a decanter allows the wine to aerate before you drink it.
Apr 10, 2013 | Home
Replaced diverter valve on worcester 9.24 combi and still only luke warm water
check your expansion vessel is not flat.if so recharge..simple way to check press in valve on vessel if water comes out or little air recharge..if water still in vessel the diaphram in vessel has split so replace vessel?hot water relys on expansion??
Dec 10, 2012 | Water Heaters
Installing a vessel sink
Standard Vanity height is approx 34.5". A vessel vanity is approx 31" high. If you cannot remove the legs from your existing vanity then it will have to be replaced or cut down to the correct height. The reason a vessel vanity is lower is because your sink will be approx 3 to 6 inches higher than a standard drop in sink. This may be more work than it is worth. Vessel sinks most often will require a solid surface top, either glass, stone or another type of composite material. The standard laminate vanity top has a particle board substrate which will detiorate quickly at the drain location.
Jul 07, 2010 | Buck 31" Granite Vanity Top for Vessel...
Heating the cup more than coffee
make sure the stirrer motor located under the outer cover that distributes the microwaves is turning otherwise you will get hot and cold spots in the oven cavity
Apr 30, 2010 | GE JVM1870 Microwave Oven
How do you care for a granite vessel sink? What
need to seal every few years---granite is like any other stone its porous and can be stained by dye products and certain oils
Apr 08, 2010 | Stone DeNovo Absolute Black Granite ...
Poor Draining of Vessel Sink
have the plumber pop an opening on the side of the drain pipe under the sink. and add a indoor vent.
Apr 10, 2009 | Advent KRAUS Amber Rectangular Glass...
Home Logo
21 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
