Question about Health & Beauty
SOURCE: moving problem
More than likely its the speed pod or engager (paddle assy. This would need to be replaced.
Posted on Jul 12, 2009
SOURCE: bmw z3 passenger seat goes forward backwards but
It can also be theseat motor since there is seperate motors for up/down & forward/backwards. You can test the switch to see if you are getting power to the connector on the motor by using a multimeter.
If there is power to the motor, I would remove the motor and give it a tap on the ground. Alot of the time the motor is fine, and the tap will free it up again. If it doesn't work you may be up for a new seat motor. Giving mine a tap solved the issue with mine.
Posted on Nov 05, 2009
SOURCE: Scooter won't move forward or backward
jdl0755, I'm having the same problem with my DKS-200. I was wondering if you determined the problem? I'll let you know if I figure it out with mine.
Posted on Dec 17, 2009
SOURCE: Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
Posted on Mar 19, 2010
SOURCE: 2004 ford escape wont go in reverse Girlfriend got
bad...burned out the trans with the constant slipping, make sure it is not out of fluid, but chances are the trans is toast-sorry
Posted on Mar 01, 2011
Dec 31, 2015 | Health & Beauty
Aug 10, 2015 | Shoprider Health & Beauty
Mar 26, 2015 | Mercury Regatta 8mph Road Mobility Scooter
Oct 03, 2014 | Health & Beauty
Apr 26, 2014 | Shoprider Scootie Jr
Jan 10, 2014 | Electric Mobility Power Electric Scooter...
Nov 04, 2013 | Electric Strider Midi 4 Wheel Mobility...
Sep 23, 2013 | Pride Health & Beauty
Dec 05, 2012 | Electric Mobility Health & Beauty
Aug 10, 2010 | Health & Beauty
16 people viewed this question
