Problem Ejecting USB Storage Device: This device is currently in use.
When I try to remove my external hard drive safely I get an error message telling me that "This device is currently in use. Close any programs or windows that might be using the device, and then try again." I have done this. I have also tried closing every program running on the computer and it does not help.
Posted by jamessteerforth on
  • Anonymous Nov 23, 2020
    do a shut down. of PC, not all apps are closed
    or look in task manager, (control + alt +_del)for some app running that must not be.
Artoria Pendragon
    Habit-Forming:
  • 27 Answers
You can refer to this article, which presents several fleshed-out solutions.
Quick Fix 'This Device Is Currently in Use' & Safely Ejecting Tips
Posted on Nov 23, 2020
How do I down load photo's from my Samsung 2 phone please
First make sure you have the correct USB drivers for your phone installed on your pc. Go to device manager and see if your phone or mass storage device is listed. If not, download the drivers here, http://www.samsung.com/us/support/downloads. Make sure debugging on your phone is enabled. Please refer to the following:
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > Applications > Development" and enable "USB debugging".
  2. Then drag the status bar down and tap on "USB connected".
  3. The "USB connected" screen with the large green Android icon will appear. Tap on "Connect USB storage".
A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 4.0)
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > More... > USB utilities" and tap on "Connect Storage to PC".
  2. Then plug the USB cable into the device and connect to your computer.
  4. A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 2.3)
Jan 09, 2015 | Samsung Cell Phones
Which mass storage device asus eee1005ha is?
The harddrive
(A USB thumbdrive is a removable mass storage device.
An external harddrive is a removable mass storage device.
A harddrive is a mass storage device that is installed IN the netbook.
NOT considered removable, therefor the one mass storage device)
Regards,
joecoolvette
Dec 17, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I have windows 98 version I want to use USB Mass storage device to my PC How can I do this
plug in the usb mass storage device into usb port in the cpu.... simple... if u ve any problem... tell me
May 14, 2010 | Computers & Internet
Hi, i put in my sandisk usb, computer sees it but wont let me store anything on it??
Your SanDisk Cruzer appears on your computer as two drives
  1. A CD-ROM ( with the icon of a Cd-Rom) that contains the U3Smart Operating system, but does not have any space for storage.
  2. A mass storage device.
The two devices are labeled sequentially if CD-ROM is E, the mass-storage drive is F, but that is not guaranteed.
You should drop files on the mass-storage device, not the CD-ROM.
Jan 02, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I want to eject Have Cruzer Titanium 2.0 USB memory plugged into computer. No programs or files from it are currently in use. After clicking on Safely Remove hardware, the message Problem Ejecting USB Mass...
Make sure you have all programs and folders closed. Then try stopping usb mass storage, there should be more then one option so try removing the drive itself on the list. If that doesn't work. I myself would probably just restart the computer. Then try again.
Thanks,
Lee
Sep 08, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My new hardware might not work properly(no detection)
ok
if your storage device not wortking properly.
Go to device manager and uninstall usb drivers from computer then install again.
May 28, 2009 | Mass Multimedia Apricorn Mass Storage...
Problem ejecting/stopping Seagate Freeagent Go 250GB hard Drive
Antivrius or another program using it...You just need to stop all servicess on task menager then stop mass strorage device
May 10, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
How can i download pictures on my SGH-G800 to my computer?
The quickest way to do this is to put your phone into Mass Storage Mode then connect it via the USB cable to your computer. Your phone shows up as a USB Mass Storage Device and you can select the folders you want to download your pictures from.
To set your phone to Mass Storage Mode, do the following:
- Go to the main menu
- Select Settings
- Then Select Phone Settings
- Choose PC Connections from the menu
- And then click on Mass Storage.
When you connect the USB cable to your computer, your phone will show up as a USB Storage device and you can just copy and past files to it like you would a USB Thumb drive. If you select the Samsung PC Studio option...your file transfers will take ALL DAY. Just use Mass Storage mode. Good luck.
Mar 16, 2009 | Samsung SGH-G800 Cellular Phone
Can't download photo's onto computer
Are you connecting your phone as a Mass Storage Device?
  1. From the home screen, attach one end of the Motorola Original Enhanced USB cable to your phone and the other end to a USB port on your computer.
  2. On your phone, press Yes to use the phone as a portable USB storage device.
    Note: When connected as a storage device the phone cannot perform regular phone activities. Disconnect to resume normal operation.
  3. On the PC, open the My Computer window and find where your phone displays as a Mass Storage icon.
    Double click the Mass Storage Device icon.
  4. Drag and drop files between your computer and phone.
  5. When finished, remove the phone safely from your computer. Right click the "Safely Remove Hardware"
    icon at the bottom of your computer screen, then select "USB Mass Storage Device" and click Stop.
  6. Select USB Mass Storage Device and click OK.
    Now it is safe to disconnect the cable. When the cable is disconnected, the phone restarts
Jan 02, 2008 | Motorola Mobility W375 Cellular Phone
Computers & Internet Logo
18 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
