Question about Garden
SOURCE: ryobi leaf blower #8544,25.4 cc
I have a McCulloch, that the hose rotted off the fuel strainer in the tank, I replace the hoses, it ran for awhile then stopped, removed the carb. an have cleaned, { 7 Times} it runs for awhile then stops, Usually I dump lighter fluid in the carb. if it starts Ign is OK if not its a fuel problem. You could check on the filter, I still have a problem with mine, its a pain when your on the roof an it stops. so check the fuel filter is the only thing I could suggest to you GOOD LUCK
Posted on Nov 11, 2008
SOURCE: gas blower craftsman leaf older modle
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 30, 2008
SOURCE: Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Posted on Sep 30, 2009
SOURCE: my leaf blower will start but wont run
fuel system needs cleaned
check fuel lines
filter
remove carburetor for replacing diaphragms/gaskets
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
SOURCE: Husqvarna Leaf Blower won't start
yes, it is. i suggest checking to make sure the plug is firing--you can check by removing it, plugging it back into the plug wire and resting the threads of the plug on any ground--usually right outside the spot where the plug screws in. have someone pull the cord while you see if the plug fires. DON'T touch the plug while the engine is being cranked. also, even if you see a spark, it may not fire inside the engine. if the spark is weak, you may want to put in a new one.
Posted on May 12, 2010
The only things I know that cause low compression is poor piston rings or a worn out or scored cylinder
Feb 18, 2014 | Echo Gas Blower 162 MPH 450 CFM Blower...
Dec 14, 2013 | Garden
Nov 04, 2013 | Husqvarna 150Bt Leaf Blowers
Feb 23, 2013 | Garden
Jun 15, 2011 | Garden
Nov 26, 2009 | Garden
Nov 08, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
Oct 26, 2009 | Garden
Oct 04, 2009 | Garden
13 people viewed this question
