Check to see if there is room inside engine compartment, i would not place inside vehicle
If you have the battery inside the Vehicle the gas of of the battery is very explosive so you want it vented well. Do not put it in the compartment with the converter because gas from the battery can build up and the converter could cause an explosion. Also the gas is dangerous to breath in. It can cause Brain aneurysms if the fumes are breathed in. So if at all possible put it out side and inside the frame rail to keep it from being hit. Also use a Truck kill switch cost about $35.00 and will carry up to 200 amps of draw on the battery that way if you have any problems at all you can disconnect it with the disconnect switch. this is a safety device to keep you safe in case of an accident. You should use the newer dry cell batteries to get rid of the gassing of the battery. If you need more information let me know.
Avid 101
Outside for sure, never inside, very dangerous. Is this a trailer or Van?
There should be an outside compartment with vented door for the battery, or a spot for it on tongue area. Look for your 12 volt electrical hook up wires outside trailer, the place for battery to mount, should be there.
Never inside. Should be a compartment on outside of trailer with vented door, or on tongue of trailer, wherever your wiring harness is .
3rd time posted!!!
