Refrigerators Logo
Alvin Curtis Posted on Nov 19, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a reset for .magic chef freezer model mcuf88w if so where Is it located? Thanks
ray gallant
Level 3:
Top Expert:
  • Refrigerators Master 74,163 Answers
  • Posted on Nov 19, 2020
ray gallant
Level 3:
Top Expert:
Answers
74163
Questions
0
Helped
655329
Points
561709
None as far as we know but perhaps magic chef would know
1helpful
Cubic feet of Magic Chef Model CTB1826ARZ/Serial 11820457JP?
21.4 cu.ft. Freezer Location - Top. Magic Chef CTB1826ARZ Energy consumption 480kwh. Annual Energy Star Saving $48
Page 79 refers
https://publications.gc.ca/collections/collection_2013/rncan-nrcan/M141-6-2012.pdf
Setting tempture
Turn the temperature control in the direction furthest away from the off setting.
Wont freeze or get cold
it has cooling problem or somewhere of wires are ligued.so you face this problem.
1helpful
Magic chef freezer model mcuf88w won't freeze
When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
We defrosted our upright magic chef freezer. When we plugged it back in, it will not work. There is a clicking sound from time to time but it only runs for a few seconds at a time.
I have the same problem, but so far, I have no resolution to the problem. My model however; is MCUF88W. There is a 1-888-775-0202 telephone number, but when I called, there is a busy tone. I need a solution to the problem.
The freezer is only two years for crying out loud. No solution here, SORRY. HELP!!!!!!!!
1helpful
MAGIC CHEF FREEZER THE DOOR IS NOT OPENING FOR 8.8 CU FT UPRIGHT FREEZER MCUF88W -- BRAND NEW JUST BOUGHT?? HELP
If You run Your finger in between the rubber seal that is resting on the freezer and the frame of the door , the rubber seal will break lose. When you open the door the seal is attache to the door.
Just had the same problem after unboxing.
Simple, just be sure to do the entire door.
1helpful
I have a Magic Chef refrigator and it freezes up
A bad defrost timer located on the right rear.
A bad defrost heater located in the freezer under the freezer floor panel.
1helpful
Magic chef refrig model # MCBR1000W defrost thermostat
RepairClinic.com is a fantastic online site for ordering appliance parts.
Where is the defrost timer on a magic chef refrigerator
The defrost timer for your model is located in the fresh food compartment. Providing the model number above your post is correct. The part number for your defrost timer is 61005388
You can visit my sites if you like and enter part or model number to get the models or parts you need. If you need help or need answers let me know.
Thanks, Sea Breeze
http://appliancepartseast.blogspot.com/
http://servicepartstec.blogspot.com/
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
