Question about Alcatel Cell Phones
My alcatel flip phone split in half and the ribbon is ripped it totally detached what can i di????? All my texts pictures, contacts everythingggggg what shud i do??? PLZ HELP MEEEEE
Posted by Sharon on
Vernon Taylor
  • 7,446 Answers
If you live in a large town or a city there is almost certainly a Phone Doctor or other repair shop not too far away. These people might be able to repair your phone but if not they should be able to lift the data from it in a similar way to how the police forensics do, though this level of service usually isn't cheap.
I hope you are successful - I hope you will backup your information next time...
Posted on Nov 19, 2020
5 Related Answers
Anonymous
SOURCE: flip screen broke in half from number flip
try finding a data cable/ USB cable. make sure to get the software and/or drivers with the cable
Posted on Mar 01, 2007
Anonymous
SOURCE: Text Messages
The text messaging is the functionality of the netwrok not the handset. Unless Verizon offer this service phone is not going to have that option. (Just like block numbers, etc.)You can call Verizon and see if they have some solutions since you are not going to be the only one with this problem.
Posted on Oct 24, 2007
Anonymous
  • 78 Answers
SOURCE: Common blank screen.. but no ribbon cable
I don't recognise the radio model number because we use different model numbers in england but if this unit has a fluroscent display that would be my first suspect
Posted on Dec 07, 2007
Anonymous
SOURCE: Phone locked! Please Contact service center!
My phone is giving message Phone locked! Please Contact service center!)
Posted on Mar 14, 2008
Anonymous
  • 9 Answers
SOURCE: How do I get the contacts out of RAZR V3?
They should be able to upload them for you to your new phone at the Alltel Store.
Posted on Mar 04, 2009
Where do I find a manual for a Alcatel 4044V flip phone
Hello, Anthony -
I checked the Alcatel website <https://us.alcatelmobile.com/ > and did not find a user's manual for the 4044V model flip phone.
If you are in the USA, you may wish to check eBay to find any Alcatel 4044V model phones for sale, contact a seller or two and find out if the phone includes a user manual. If so, ask the seller if she / he would be willing to photocopy the manual and sell you the photocopied document.
I can not recieve text messages on my alcatel one touch
Troubleshoot issues related to text messaging on your ...
support.sprint.com/...text-messaging...ALCATEL-One...
Sprint CorporationUnable to send or receive text messages; Displaying error codes or network messages when you try to send a text message ... A soft reset reconnects your Alcatel OneTouch Retro to the Sprint network. ... been able to text, contact Sprint Customer Care for further troubleshooting. ... Under My Products, click on Edit Products.
Troubleshooting Basic Phone Functions ' Brightspot Support
Codice dimenticato
Qual ? la vostra marca di telefono e MODELLO?
Se Nokia DCT o del modello del telefono Alcatel Vecchio significa che ? possibile sbloccare il codice di sicurezza utilizzando il codice master reset, credo che hai dimenticato la code.So ottenere il codice di sicurezza Ripristino totale da qui
Unlocking4free e reset
Jul 11, 2011 • Cell Phones
1helpful
2answers
I have a Motorola Razr V3. Very recently the exterior and main screen went black. The phone itself still works (I can still call people and receive calls) but I can not see anything on the screens. Do you...
The reason your phone interior and exterior screen went black is because there is a problem with the flex of the phone.
The flex is the mechanism like a ribbon that connects the screen to the panel of the phone.
All you have to do is to replace the flex of the phone.
To replace it on your own, the process to do this are as following;
  1. Get the appropriate screwdriver (Torx 5 screwdriver).
  2. Remove the four rubber stoppers surrounding the screen to reveal four screws. Remove these screws.
  3. You can now remove the front cover. To do this, use a credit card to lever the cover up. The cover clips on and the levering motion will unclip it. Start at the top, then unclip the cover at the bottom, then both sides.
  4. Now detach the camera from the phone. Simply pull the ribbon away from the phone to release it.
  5. Now unplug the other ribbon. The ribbon attaches like a plug and socket. Simply lift it up to unplug it.
  6. The ribbon you just unplugged is the flex of the phone, so you have to unscrew the lower part of the phone to remove it completely.
  7. To open the lower part, you have to open the back cover and remove the battery,
  8. Unscrew the screws you see, than split it open with a credit card or the tip of your finger, apply a little force to open it.
  9. Then unscrew the board, you will see where the other end of the ribbon is connected on the board, then you can remove it and fix a new one.
  10. Reverse the process to reassemble the phone together.
Take care
3helpful
How do you fix the loose cable ribbon to the LCD screen? The screen is on and lighted but I cannot see any information. No Caller Id, text messages or contact info.
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
BLANK
there is a ribbon connector between the bottom half and the top half of your phone, this carries all the information for the top half ie picture & sound etc. It is more than likely that this cable is damaged someway. you would need to disassemble the phone and check the plastic ribbon carefully to be sure.
Cell Phones Logo
Top Alcatel Cell Phones Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
