Question about Electrical Supplies
Generator does not provide power - Electrical Supplies
Posted by Jamie Aksel on
MODERATOR USA
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Electrical S... Master
  • 37,621 Answers
Make model killowatt output?? portable or standby???
Posted on Nov 16, 2020
Onan 7000 generator runs but does not produce electric to rv
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
Mar 19, 2014 | Watts Onan Portable Generator - 4000 ,...
My Makita G5500r power generator doesn't have smooth Idle?
sounds like the carb needs to be cleaned inside any fuel the was left in the carb goes bad and it never runs it all out
Sep 06, 2012 | Electrical Supplies
Honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
May 31, 2012 | Honda Eu3000is
Need to know each step in removing a bad alternator from 2003buick rendezvous all wheel drive
Remove the battery ground (negative) cable from the battery.
Remove the throttle body air inlet duct.
Set the park brake.
Shift the transaxle into Neutral.
Remove the engine mount strut bolts. Swing the engine mount struts aside.
Install tie strap between the engine and the radiator support.
Pull on the engine in order to rotate the engine forward.
Tighten the strap.
Remove the generator B+ terminal nut.
Remove the generator B+ lead.
Remove the generator electrical connector.
Remove the drive belt from the generator.
Remove the generator front bolt.
Remove the generator rear bolts.
Remove the generator from the generator bracket and position the generator above the drive axle.
Remove the drive belt tensioner.
Remove the generator bracket.
Remove the power steering pipes from the power steering pipe retainer.
Remove the fuel pressure test port (schrader valve) cap from the fuel injector rail.
Remove the power steering pump and reposition the power steering pump in front of the timing chain cover in order to provide access for the generator.
IMPORTANT: Do not disconnect the power steering pipes from the power steering pump.
Remove electrical harness from retainer on right fender well and position aside.
Remove the generator from the vehicle.
Reverse procedure to install
Aug 22, 2011 | 2003 Buick Rendezvous
Clocks run fast when generator is providing power
Check your output voltage and frequency on the generator when you are connected to it.
Jun 20, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
Alternator mounting diagram
1999-2005 To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • The negative battery cable
    • The windshield wiper system module cover (if equipped)
    • The fuel injector sight shield (if equipped)
  3. Rotate and secure the engine forward.
  4. Remove or disconnect the following:
    • The generator B+ lead
    • The generator electrical connector
    • The generator from the generator bracket and position the generator above the drive axle
    • The drive belt tensioner
    • The generator bracket
    • The power steering pipes from the power steering pipe retainer
    • The fuel pressure test port (schrader valve) cap from the fuel injector rail NOTE: Do not disconnect the power steering pipes from the power steering pump.
    • The power steering pump and reposition in front of the timing chain cover in order to provide access for the generator
    • The generator from the vehicle
To Install:
  1. Install or connect the following:
    • The generator to the vehicle into position above the drive axle
    • The power steering pump to the engine
    • The fuel pressure test port (schrader valve) cap to the fuel injector rail
    • The power steering pipes to the power steering pipe retainer (if removed)
    • The generator to the generator bracket and position the generator above the drive axle
    • The generator front bolt
      1. Torque to: 37 ft. lbs. (50 Nm)
    • The generator rear bolts
    • The drive belt
    • The generator B+ terminal nut
      1. Torque to: 115 inch lbs. (3 Nm)
  2. Position the engine rearward.
  3. Install or connect the following:
    • The engine mount strut bracket bolts
for removal to reposition the engine
Feb 15, 2011 | 2000 Pontiac Montana
PF 2500 watt generator... Need plug and oil
30wt oil, probably a Champion RN4C plug. Could give link to a manual if part / model number of generator was provided.
May 17, 2010 | Coleman Powermate Proforce 6,000 Watt 12...
I have a kipor ig6000 generator.When i connect my espresso machine to my generator it sends the pump haywire which overfills the boiler.This is certainly a fault of the generator because the espresso...
Your generator is running a bit too fast, and the frequency is greater than 60Hz. Most generators are setup for 62-63Hz no load. You can adjust this at the governor for the engine.
Another possibility is that the alternator is providing electric with a large amount of harmonic distortion, which some appliances don't tolerate well (dirty power). Try adding a noise filter between the generator and espresso maker and see if that helps. The espresso maker may also expect to be grounded, which the generator is not able to provide (unless you are driving a ground rod). The noise filter may also require a ground as well.
Dec 03, 2009 | Electrical Supplies
Need more amperage from generator.
No! The two receptacles are already connected together where they take power from the generator. Two are provided so that you can plug in two items, but the total power must not exceed the rating of the generator.
May 23, 2009 | Honda Generator Engine Parts Air Filter...
Electrical Supplies Logo
21 people viewed this question
Top Electrical Supplies Experts
Marvin
Marvin
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
