Question about JVC Televison & Video
Why don't TV speakers work?<br> - JVC Televison & Video
Posted by Regina Chumbley on
ray gallant
    Top Expert:
  • JVC Master
  • 71,004 Answers
CAN NOT GUESS BUT YOU MIGHT HAVE HIT THE MUTE BUTTON ON REMOTE
Posted on Nov 15, 2020
Getting tv sound from home theater speakers
Connect your sound from the cable box out to the JVC theater audio in jacks. This will give you sound through the speakers.
Jan 29, 2014 | JVC TH-C50 System
I would like to use my jvc home theater while watching tv. But i have no idea how or what wires to use to make this work.
You will need a 2RCA to 2RCA audio cable as shown below. Connect the audio out socket of your TV to the Aux or TV/SAT input of the JVC. When you want to hear the TV sound through the JVC system just select the appropriate input on the JVC. If you want the surround speakers to work, select ProLogic or All channel stereo on the JVC's surround settings.Because by default the radio or TV sound is only stereo, so only the front left and right speakers will work. PLII will convert 2 channel to 5.1.
Apr 26, 2011 | Audio Players & Recorders
Cannot get home theatre to work with panasonic flat screen. Surround sound was working with old tv got a new one but now its not working. Do i need a different cable
your new tv probalby has an hdmi output. depeding on how old your jvc system is, iit may or may not have an hdmi input. not to worry, there should be some type of compatible output on the tv to send audio signal to the jvc. first look at the back of the jvc and see whats there. then look at the tv and you should see compatible output on tv and run proper cable to input on jvc. some auxillary audio outputs on the tv are driven by the volume of the tv itself, so make sure to turn the volume on the tv up a llittle to make sure its sending signal. you may have to go into the tv menu and turn the internal tv speakers off so you dont hear them and the jvc. its not a big deal if your hearing both, it just wont be true surrond sound. if it were mine, id turn the tv speakers off.
Dec 24, 2010 | JVC TH-C40 System
My flatscreen tv is distorted
Speakers can cause problems with the correct display of video on TVs but usuall it only concerns direct view tv. Projectors should not have any problems or flat screens. I think you have a different problem Explain better what you mean by distortion in the JVC. Let me know and I will try to help you.
hardrocko
Feb 06, 2010 | JVC LT-42E478 42 in. LCD Television
Cannot figure out how to hook up my jvc th c5 to my tv & cable tv
Do you have audio outs on you tv to run to the jvc
Mar 15, 2009 | JVC TH-C5 System
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
Sound Problems with JVC AV-35BP4 TV
The audio output stage for the speakers may have failed in the TV set. If the set has an earphone jack, it is also possible that the jack has a fault (very rare, but I have seen this).
Are there external speaker outputs to try other speakers?
Jerry G.
Apr 29, 2008 | Televison & Video
Hi there!
The amplifier section may be at fault. Could also be IF or dry joints in that area. Also check the speakers(Highly unlikely though) Good Luck,JUS004
Feb 24, 2008 | Televison & Video
Lost sound on JVC TV
http://www.amazon.com/JVC-AV-48WP30-Widescreen-HDTV-Ready-Rear-Projection/dp/B000066R7X
Cut and paste this link. Amazon's page has a link to the JVC manual. That'll tell you what you need to know
Jan 21, 2008 | JVC AV-48WP30 48" Rear Projection...
Speaker settings
u shoudl run cable back form tv main outs to input on sterio has to be in prologic modes to get all sopeakers to work ok not streio 2ch on reciver use dsp modes only
Jan 20, 2008 | JVC RX-884V Receiver
Televison & Video Logo
16 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
