This bracket is for unit door hinge it has fallen inside w/m i cannot find a way to retrieve it..can i get to it or can i replace-any help grateful thanks
I have the same model Miele and ordered a replacement part. I have 2 Miele ovens side by side, and a door hinge on both ovens began to malfunction. I ordered and received the hinge , but when I started to install it, I found that the hinges were fine! The issue was that the 3 screws that hold the hinges to the oven frame came loose. One of them had fallen out on each of the doors, they had to be jiggled in order to close properly, which was not satisfactory. The ovens were installed 13 years ago by the original owners.
You will need to slide the oven out of its enclosed space and unscrew the sheet metal siding in order to gain access so that you can unhook the coil spring attached to hinge. I found that one of the small machine screws has fallen out on the 2 malfunctioning hinges. Once the spring is unhooked, you can align the hinge to screw it back in, and tighten the other screws that hold the door hinges. The screws on the other side has also become loose.
The last person who used the oven door as a shelf to rest a heavy roast has bent the bracket the hinges go in to. A piece of dowel (broomstick) cut to the width of the oven and placed as a fulcrum in the hinges, gentle pressure when almost closed can bend it back into position, but that wont last. >> Replace front frame or retention brackets
Not being able to see the problem, may I suggest you beg, borrow or steal a couple of strong magnets to hold the plate in place while you attempt to re-attach the doors.
Once you got one more or less in place you can use a nail or small screw driver maintain or adjust position.
jenn air had some issues with there hinges wearing fast in prior years on there ovens and then you have the ones the kids use as a trampoline sometimes or the heavy turkeys laying on the door while it is opened... there really isn't any adjustment for the door the hinges bolt inside and are held in one place by a few screws ...they are replaceable as welll as the door gasket on the unit... hope this helps you out some... alot of the appliance sites out there will be able to assist you with parts such as www.sears.com then click the parts direct link up top have your model number usually inside unit either on door or inside where door closes... some units between door and cabinet area... good luck to you
You should be able to repair your existing door.
Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle.
Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place.
You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
The only to do it, is to remove the side panel , and depending on the model number, you may have to remove the top also to gain access to the fixing screws.
Please rate my solution.
Thanks.
These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
Then reassemble.
My door now feels like a new one even though it is 15 years old.
You have to remove the inside skin of door, pull door up and off of hinges and lay on floor to make this easier. Then you remove clips or brackets that hold the glass to door and clean. Very simple, but time consuming, mainly lining skin back up on reassembley.
I had exactly the same problem until tonight!
I had nothing to lose so solved it by sheer brute force!
The problem is with the hinges that the door clips into they seem to get very loose. If you can manage to crimp them against metal they won't move and your door will shut properly. This is how I did it.
1. There are a couple of locks (levers) on each hinge open them up and then lift off the door
2. Ensure that there is nothing wrong with the door brackets, tighten the screws on them to ensure they don't move.
3. Fit the door back on to the hinges and with the levers still open(towards the door) push the door against the hinges which bends them tight in position (don't push too hard otherwise you will completely bend the bracket out of shape you just need to do it enough to crimp it in to place and prevent it from moving)
4. Now open the door, push the levers back closed against the hinges and then shut the door. Hopefully it will be a much tighter fit.
