Question about Garden
I just need to know do i have plug it in the winter or can i leaf it off 2004 f-150
Posted by Juan Luera on
Vernon Taylor
  • Garden Master
  • 7,428 Answers
It depends on what sort of winter you experience. You should ensure there is enough antifreeze in the coolant and the screenwasher system and keep the battery fully charged and ensure the routine maintenance is up to date and the vehicle should remain a reliable starter, though in fairness dampness is a greater enemy than cold - as the temperature drops it tends to dry the air.
A petrol engine in good condition should start reliably down to -15 C and beyond though warm-up time will be rather extended (until the heater begins to work). Reliable starting when the thaw sets in is a bigger problem.
Diesel engines aren't as good in very low temperatures and have to be in particularly good condition to start reliably in below freezing conditions...
Posted on Nov 12, 2020
Stihl blower won't spark.
check the key in the flywheel,any wear in the key can cause it to be out out of time and it will cause no spark at the spark plug.
Jun 06, 2015 | Stihl Garden
My stihl backpack blower will not start
Check for spark? Been sitting all winter? Carb is all gunked up with varnish..... Many possibilities. Start with plug first. Let us know more if you need more answers.
Mar 02, 2015 | Stihl Garden
When is the time to winterize rose bushes and how do I do this
I don't like to cut them all the way to the ground I keep them about thigh height. Mix up a bucket of mild bleach solution to dip your clippers in. Wearing gloves, locate a healthy leaf and cut just above that point. Dip clippers in bleach solution between each cutting to avoid transferring any nasties.
Finally using white glue seal the cut tips. Best time to do this is well before the first frost in autumn.
Oct 09, 2014 | Bon-Ton Nearly Natural Rose Bush with Vase...
Spark plug gap chart
.028 is common for hand helds
Sep 13, 2013 | Stihl Garden
Homelite 26 BV Gas Leaf Blower
sounds like you had fuel leak into the cylinder over the winter. The liquid in the cylinder is what made it so hard to pull that first time, as it won't compress like air. What you do, is take the spark plug out, pull the starting rope several times, dry off the spark plug, and let both sit(plug out of the cylinder.) for a couple of hours. Then put the plug back in, put the wire back on it, put it on full choke, and pull until it hits once. Then put it on half choke, and pull til it starts.
Mar 28, 2010 | Homelite Consumer Products 7 Amp...
Won't start after replacing the plug. there is fuel.
get another plug theres a lot of bad small engine plugs on the market that are no good right out of the box! i run into 15 last summer working on weedeaters and chain saws and lawnmowers
Jan 15, 2010 | Homelite 'Yard Broom' Leaf Blower
Need to know specifications of spark plug for Ryobi Leaf Blower
You can download the manual at www.managemyhome.com. I have the Ryobi 720r and the sparkplug is a champion RDJ7Y.
Jul 11, 2009 | Ryobi Garden
Echo PB1000 leaf blower will not start
Check fuel lines and fuel filter. If unit has been sitting all winter carburetor may need to be overhauled.
Mar 29, 2009 | Garden
Mower
If it sat for some time without running aslittle as 30 day the fuel is probly stale and needs to be drained and the carb cleaned and possibly a new spark plug
Jan 31, 2009 | Toro Blowers Rake and Vac - Electric...
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
