Question about Cameras
What if I lost power on a firmware update via SD card on a vx7022. What do I need to do if it doesn't work?
Posted by Jason Pagoria on
Andrew Taylor
    Top Expert:
  • Cameras Master
  • 35,011 Answers
You can try removing batteries and then try the update again. Firmware updates must be the only thing on the SD card and the update package must be unwrapped. Read the instructions carefully. Sometimes a second update will work, but Firmware updates alter what happens before the operating system loads. Usually, the device has to go back to the maker.
Posted on Nov 10, 2020
Richo afico 5002 code sc 878
1. Improper firmware update.
2. SD Card size greater than 2 GB used.
3. Multiple ROM data folders in SD Card.
4. Improper Java firmware update.
5. Power failure during firmware update.
6. Power line issues on the outlet.
Replacement of the Controller Board is necessary in case SC Code 878 occurs.
Apr 11, 2017 | Ricoh Aficio Office Equipment & Supplies
Why does kocaso scan my SD card and reset to factory settings every time I power it on?
You need to reload the firmware as it cannot find working android operating system. It also cannot find the firmware program on the SD card which needs to be blank, when you write the firmware load on a PC.
See instructions here. Support Firmware
Jan 12, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
Garmin nuvi 3760. I have downloaded North american maps to the SD card but the Nuvii doesn't recognise the SD chip map when I go to tool, maps etc. Help
Update your unit using Garmin Webupdater. The latest updated firmware allows the units to read all sd/microsd cards You can download garmin webupdater from here: http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Download install and run the program and follow the on screen prompts to update your unit.
Sep 27, 2011 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
Hi, my reader is saying "android.process.acore has stopped" Force closing won't work. I know firmware update via zip file is available but it's midnight here and I don't have an sd card handy....
Sorry to hear your are having issues with your Cruz Reader. I have a Cruz Reader R101. Unfortunately you have to update via the SD card for the Cruz Reader. It doesn't do a firmware update from the USB cable.
If you don't want to try and update it now you could also try to just restart it. If you can't get it to restart normally you can remove the back cover and unplug the battery, then plug it back in.
Apr 25, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
I have a g1 and it downgraded to 1.0 how can I upgrade it without a manual update
How to Update G1 Phone Firmware RC33
1. Download RC33 update from Google here.
2. Rename the download file from signed-PLAT-RC33-from-RC30.f06aa9b3.zip to update.zip, and place it at the root i.e the very top directory of your Micro SD card. (If you added the file to your microSD card by connecting the handset to your computer via USB [rather than using a dedicated microSD card reader], make sure to unmount it and disconnect the USB cable now.
3. Turn off your G1 Make sure it's completely powered off. Now again turn it on by holding the Home+End keys until you see T-Mobile G1 logo.
4. From the icon screen, open the keyboard and hit Alt+L.
5. Press Alt+S to begin the update. Remember, the update needs to be in the root of the Micro SD card and needs to be named update.zip.
6. Once it finishes, follow the onscreen instructions and press Home+Back to finish.
7. G1 Phone will reboot a few times to flash different parts of the firmware.
If all went well, you should now be running the latest update, RC33. Enjoy your new, shiny RC33 update, complete with Google Latitude!
To make sure all your hard work wasn't for nothing, hit Menu > Settings > About Phone > scroll to Build Number. You should see RC33 in there somewhere.
Mar 23, 2011 | HTC G1
Hi can you tell me how to get my camera to recognise my sd card on my casio exilim ex-z500. I have tried reformatting but this hasn't worked.
Is it a SD card, or a SDHC (High Capacity) card of more than 8GB? Because the EX-Z500 natively does not support Large-SDHC.
Power off the camera. Press and keep pressed the MENU key, and while doing this, turn on the camera via the ON button. Press the MENU key until the firmware revision is displayed. I suspect you will see V1.01 or V1.00.
And Large-SDHC support is only present in release V1.02 of the Z500 firmware.
You should have the firmware updater-checker software; if not, you can find it on Casio website:
http://support.casio.com/download.php?rgn=4&cid=001&pid=170
This should fix it up. Let me know if it works.
Jun 14, 2010 | Casio Exilim EX-Z500 Digital Camera
How to update firmware via cable?
The explaination is on the Canon firmware download page. http://web.canon.jp/imaging/eosd/firm-e/eosdigital4/firmware.html
Basically it is done via the EOS Utillity that comes with the camera.
There, click the [Camera settings / Remote shooting] button and then the Tools symbol.
Dec 22, 2009 | Canon EOS 450D Digital Camera
Pentax Optio S not functioning
I don't know if it would help but try to update the firmware for the camera.
Jan 01, 2008 | Pentax Optio S Digital Camera
Cameras Logo
Top Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
