Tablets & eReaders Logo
Question about Tablets & eReaders
How can i do a hard factory reset on my jp5s prison tablet now that I'm released
Posted by Kathy Allen on
Does anyone know any information on how to factory reset a prison style tablet. Hiteker u804mc anything relevant please.?
Do you have 'Administrator' access on the tablet? This is where you can get into the main Settings area of the tablet. If it is a prison style tablet the sign in details for the inmate would have been severly restricted with no access to the settings.
If you can access the settings go to 'Privacy'. There should be an option for a 'Factory Data' Reset. You should be able to do a full reset through that option.
2answers
How do I factory reset a jp5s
Press and hold Volume up and Power button at the same time until you boot into the Android system recovery.... Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
How do you reset and use a jp5s tablet like a real tablet without PC.
try this hold volume up and and power button at the same time when screen comes up release both power and volume up button recovery mode will come up go down with the volume down to wipe data press power button select go down to yes select it and then it will erase may go back to recovery mode go to reboot and it will restart select it
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
How do u factory reset my RCA tablet
well, i don't know what model tablet you use.
but generally you can do hard reset by this way:
1. off the tablet
2. with tablet is off, press and hold volume + (up) button and power button. release both of button when you see boot screen.
3. use volume up/down to scroll the menu, scroll to highlight "Wipe Data/Factory Reset".
4. press power button to select
5. scroll to highlight "Yes -- delete all user data" and press power button to confirm and wait until done
6. select reboot now when finish
just google RCA tablet hard reset for more detail explanation. good luck
How do I reset it
Hard or factory reset is also called as master reset
  1. Power the device off. ...
  2. Press and hold the Volume up button then press and hold the Power button.
  3. When the Samsung logo appears, release all.
  4. Select wipe data/factory reset. ...
  5. Select Yes -- delete all user data.
  6. Select reboot system now.
How Do Hard Reset My Samsung Galaxy Tablet Perform hardware factory reset Samsung Galaxy Tab reg 2 10 1
3helpful
Locked out of my tablet by my child entering a new pass word...
To unlock your tablet, you will have to perform a factory/hard reset of the device.
Performing a hard reset will DELETE ALL DATA from internal device storage and reset the tablet back to the state before you turned on the device for the first time. Resetting the tablet does not erase any system software updates you have downloaded or any files on your SD memory card, such as music or photos.
To perform factory/hard reset please follow those steps:
1. Turn the power off.
2. Press and Hold the Volume Up and Power button at the same time.
3. When the start up screen show (Samsung logo displays on the screen), release all the buttons.
4. Use the Volume Up/Down button to navigate to "wipe data/factory reset", select with Power button
5. Select "wipe data/factory reset"
6. Select "Yes -- delete all user data"
* Allow several minutes for the factory data reset process to complete.
7. Select "reboot system now"
* Allow several minutes for the reboot process to complete.
Top Tablets & eReaders Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
