Question about Kenmore Refrigerators
Other than the motherboard being bad what would cause a Kenmore refrigerator model# 795.78312.802 to quit working?
Posted by Julie Roler Mickow on
Victor
Bad evaporator fan -
Posted on Nov 10, 2020
Tom Chichester
    Top Expert:
  • Kenmore Master
  • 61,169 Answers
1. Compressor failure
2. Temperature control failure
Posted on Nov 09, 2020
On a Kenmore side by side refrigerator that has two light bulb sections, what causes the lights not to work?
The door switch provides a source of power to two things. Yes the door switch can be bad. What is your model number? There was some models that left the lights on when the door was closed and people would unscrew the bulbs just to sell them to people unaware. That problem was related to a bad relay on the motherboard
APPLIANCE 911
Nov 28, 2015 | Kenmore Refrigerators
Ice dispenser on 31" kenmore elite model # 795.7253.110 quit working
the pump on the back of refr might be shot.if there is no water in the ice tray look on the back make sure that your supply line works. If it does the pump is bad.
Jun 12, 2014 | Kenmore Refrigerators
Model 10653542300 side by side - something burnt up and now it doesn't work. What could have burnt up?
either the ptc overload relay on the compressors side body quit or the motherboard in the back of the unit has destroyed itself
Oct 14, 2010 | Kenmore Refrigerators
My GE Profile (PFS22SISBS) freezer not getting cold enough
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 18, 2010 | GE Energy Star PDS22SIS Stainless Steel...
Drain pan over flowing
The rubber seal on the water filter is bad . Replace the filter in the bottom kick plate . When the filter goes bad , water will drip into the drain pan , causing it to overflow .
May 12, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer quit working on '04 Kenmore Trio Elite 25' bottom
Can either be starting components for compressor, or Motherboard.
May 04, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Foul rotting vegetable type odor in top of Kenmore refrigerator
If the icemaker motor or heater short out it will cause a foul odor. I have never heard it described as cooked broccoli, but it can be pretty bad. Remove the icemaker and inspect the bottom of it where the heater element is and remove the white cover of the motor and look in there. You can take the three screws out of the motor module and see if anything is burned on it.
If you can rule out the icemaker, the next things to check would be the evaporator fan motor and defrost heater. Generally, if a fan motor starts causing an odor it will stop running completely and if a defrost heater goes out it will quit defrosting. It is possible, but unlikely, that something has gotten into the evaporator area and is sitting on the defrost heater so that it is "cooking" during the defrost cycle.
Check the icemaker first, it is the most likely cause of the odor. Post back with complete model number if you need further assistance and we will go through checking everything else.
Oct 24, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
