How do I convert glowarm natural gas 30000 btu wall heater to propane
Posted by Jeff Arbaugh on
ray gallant
    Top Expert:
  • Heating & Co... Master
  • 71,004 Answers
SORRY BUT YOU NEED TO ASK A PROPANE PROVIDER MANY IT CAN NOT BE DONE
Posted on Nov 09, 2020
5 Related Answers
bigg t
anthony james
  • 640 Answers
SOURCE: converting a pitco frialator from natural gas to propane
you need to change the pressure regulator,burner orfices and possibly the gas valve.goto northernparts.com and type in the model of the fryer for propane
Posted on Dec 12, 2007
Anonymous
  • 137 Answers
SOURCE: can i convert my dyna glo 75000 btu propane
I'm sure you can, contact the manufacturer and ask if they have a natural gas jet or orfice for your model heater, these are usually very easy to replace.
Posted on Feb 28, 2009
Anonymous
  • 22 Answers
SOURCE: convert a procom heater from propane to natural
you need to find a place that makes your type of heater and they will have a change over kit all it is different orfices and jetcovers for each gas jet from your heater its self explanitory once you see the parts,sometimes there are different gas comp. that if you use there service they will change you over at no or little cost. hope this helps
Posted on Sep 15, 2009
panilling9
panilling9
  • 284 Answers
SOURCE: i have an empire wall heater that was converted to
you will need a propane conversion kit designed for that particular model heater.
which would most likely consist of a heavier spring for the gas valve and orifices for the burners depending on how many burners you have.
Most all gas heaters come thru the factory set up for natural gas and most have a kit available for conversion to LP (Propane) You will also need a manometer or a gas pressure tester to check the incoming and outgoing pressures from the green (2ndary )regulator outside your house to the gas valve inlet side,usually 11 to 14" WC( water column) pressure( static) 14" being MAX!!
Outlet pressure with burners running 10-11" WC approx. This info should come with the conversion kit if available. If you are not comfortable working with gas then find someone who is, for safety reasons.
Posted on Jan 31, 2010
SOURCE: how do I convert vanguard VMH26TPA wall heater
You would have to get a conversion kit, which usually
is new orfices and a spring that goes into the gas valve. The kit would probably be cheaper than buying a gas valve and the orfices seperately
Posted on Feb 11, 2010
Can u get right orfis from propane company to fiut heater
You need a conversion kit reg injectors etc . Some models do not convert check with makers first .
Dec 10, 2017 | Heating & Cooling
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Can I convert a rinnai rce-229a from propane source to natural gas source
It should be. You should be able to replace the oriface and the regulator. Propane is at a higher pressure than natural gas.
Aug 01, 2012 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Can and how converting a 125,000 BTU Laars natural gas heater to propane?
not advisable by manufacturer but you have to change the gas valve and orfices nad mark the inside cover so repair man knows it was converted
Jan 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
I brougt glowarm space heater model HDB30PT for propane gas but I needed a natural gas space heater.Can I covert it to natural gas and how can do it for me
I'm sorry to report there is no gas conversion for your DESA heater. In fact, no vent-free (vent-less) gas heating appliance (that includes gas log sets) is approved to be converted from one gas type to another. If you bought it from a retail store, exchange it for a LP Gas Model or a refund.
Hope this answered your question and thanks for choosing FixYa.
Sep 20, 2011 | Desa International GWP20T GLOWARM Wall...
30000 btu reddy heater is throwing flame way out of the heater
The gas pressure is way to high... you need to adjust the regulator to a low pressure or replace the regulator...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Dec 10, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
Wall heater emits smoky odor, pilot is yellow
Is this is a natural gas heater connected maybe to a LP/ propane gas?
That is what first comes to mind. In any case a good blowing out will get that flame a little prettier. But if you are using the wrong gas nothing can fix your problem. These heaters are not convertable like a stove. They are built to work for a specific gas.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 30, 2010 | Desa International GWP20T GLOWARM Wall...
Can i convert my dyna glo 75000 btu propane
Feb 28, 2009 | Heating & Cooling
Natural Gas To Propane on a model # Vn2000bt
There should be a conversion kit that came with the unit plus installation instructions. If not, then the type of kit you need will be identified in the unit paperwork. You may want to have a technician perform this task if you are unsure in just the slightest. Natural gas and propane use different sized nozzels for dispersing the gas for proper ignition. If not installed properly it could cause incomplete combustion, which = CARBON MONOXIDE = ETERNAL SLEEP. Hope this helps!
Dec 09, 2008 | Desa International GWP20T GLOWARM Wall...
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
