I am getting dishes left dirty after a wash cycles. They also often have soap residue on the back of plates etc. They are not always in the same part of the dishwasher. Sometimes in the top basket sometimes in the bottom, on either side of the dishwasher The whole cycle seems to go through seemlessly so I have not idea what is going on. I regularly use the Finish dishwasher cleaner and it has not made a difference.
Its not soap residue. The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
You can probably either unscrew a knob and remove the wash arms or they'll snap off and on. Take off the wash arms and make sure there aren't big chunks of food collected under there. If there's a plastic washer in the wash arm assembly, and it's looking worn, you'd be surprised how much quieter and better your machine will run by replacing it.
Hi
The white residue is from the new environmentally safe soap. Check
your soap and see if it is phosphate free soap and that will be your issue. Also
either you have hard water or you're seeing either calcium or lime deposits. You
should use the jet dry for every load. There should never be any suds in a
dishwasher. Do not use liquid dish detergent for the dishwasher.Try running a
load without dishes, using vinegar, or a bottle of Dishwasher Magic. Another
possibility could be you're not getting enough water. The level should be close
to the heater(check your tech sheet to be sure). The water temp should be at
least 140 deg.F (no matter what the box says) Also, use a good brand of
detergent (Cascade) and be sure your wetting Agent dispenser is full. (jet
dry)You should not have to pre-wash your dishes..just scrape them well.The
detergent actually needs some dirty dishes to work properly..fats, protien,
etc. to make up 1 more chemical for the detergent.Another important step is to
run the hot water faucet before running your d/w to "purge" the cold
water out of the line.
Also check this links for some helpful information:-
http://www.appliance-repair-it.com/dishwasher-leaves-white-film-on-dishes.html
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6192
Please get back to us if you have further query else please accept
this particular suggestion.
Thanks for contacting fixya.com
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
l'l
