Question about Golf
Break not releasing in the golf cart - Golf
Posted by Palaniswamy Sundaram on
Dariusz Zalewski
  • 1,059 Answers
Corrosion by break pedal. Clean and lubricate
Posted on Nov 01, 2020
Governor on my golf, I would like to remove it.
Travis, Removing governor from your cart. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to remove governer on Club Car golf cart
How to Adjust an Go Golf Cart Governor
How to Take Governor off Club Car Gas Golf Cart
Aug 07, 2016 | Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
Jan 24, 2016 | Golf
Shuttlecraft golf cart
golf cart ? sorry do not play golf as its a snobs game so i know nothing about golf carts
Sep 01, 2014 | Cars & Trucks
Adjust break
Follow the brake cable from down the cart until you find the tension bolt. To tighten turn to the left. If you are not comfortable working on the cart, most bicycle shops can repair them for a small fee.
Sep 04, 2013 | Sun Mountain Sports Golf Speed Cart V1
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
Golf Logo
14 people viewed this question
Top Golf Experts
ray gallant
Bill Boyd
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
