Carrier 38CKC036 Air Conditioner Logo
Anonymous Posted on Sep 20, 2009
Air not coming thru ducts
Just had maintence done for cleaning on my air conditoner now
two days later air conditioner is running but no air is coming thru the ducts.
  • Anonymous Sep 20, 2009
    just had maintenance cleaning of air conditioner thru nicor and now two days later no air comes thru air ducts why
Kody Lawrence
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Nov 07, 2014
Kody Lawrence
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
2036
Points
7
My moms ducts were not blowing air through to well either. I think she just had them cleaned and they worked a lot better. I should look into getting mine cleaned as well. <a rel='nofollow' href='http://www.PowerVacToronto.ca' >
http://www.PowerVacToronto.ca</a>
Terence Fourie
Level 3:
  • Master 909 Answers
  • Posted on Sep 20, 2009
Terence Fourie
Master
Level 3:
Answers
909
Questions
0
Helped
375309
Points
2542
Very possible the long bladed fan is stuck. Possibly when filters were cleaned and replaced, a part is touching the blade. Remov filters and turn blade by hand. Does it move freely.(make sure unit is off when turning the blade.
Air conditoner runs for 2mins then shouth off code E1 comes up
Good Day, whats the make and model of your air conditioner so we can assist you better. Check us out at Airbulance Reviews.
How to remove face cover for cleaning
The front covers are usually snapped into place. Grab at top and bottom and pull. It should pop right off. GOOD LUCK FRIEND.
1helpful
Fan runs but no cool air or any air coming thru ducts
Be sure the "fan running" noise you hear is actually the fan and not just the refrigeration pump. The unit would still make a running noise but the fan may not be turning.
Check to be sure the filter is clean and that all vents are open.
My air conditioner expels black fuzzy pieces of a dust like stuff. It is only noticed after it has been on, laying in the general area.What is it? And how do i get ride of it. We have a Major Highway...
Hi and welcome to FixYa. I am Kelly. Using the model number BCA101R this is a through the wall Air Conditioner. With long term use Air Conditioners build up dirt on the blower fan even IF you clean the filter on a regular basis. The particulate that builds up on the blower wheel is very fine. If you look closely at the particulate it appears black but most of the time is a very dark brown. That is dirt build up that is loose on the blower wheel and passes freely out the louvers when it comes loose from the blower wheel. When an Air Conditoner is on for long periods day after day there should be a routine maintenance cleaning schedule for the unit. Light use you can get by with cleaning it every 6 to 9 months. With heavy use you will have to clean it every 90 - 120 days. Cleaning involves removing the blower motor and power washing the evaporator and condenser coils along with the blower wheel and the rear fan blades. Anytime a power washer is used it is VERY important never to spray pressurized water at an angle other than straight on as it will bend the fins of the coils. Once the fins are bent straightening the coil fins can be a major hassle. This cleaning can be done by the home owner but.... the home owner must be able to follow electrical safety precautions by making sure the unit is not powered and that the run capacitor has been safely discharged. The control panel must also be disconnected and removed to perform proper cleaning.
Thanks for using FixYa.
Kelly
1helpful
Kenmore air conditoner model 580.75151500 keeps blowing the built in breaker on the cord. Air conditioner is only about two years old. Happens no matter where I plug it in
Hi there. Clean the condenser. (the outside cooling coil where hot air comes out.) Use compressed air. If no air, try a vacuum.
Thanks
Paul
1990 model RUUD AC unit. Fan runs, no cooling
Is the outside unit running? Fan and compressor?
I HAVE AN AMERICAN STANDARD HEAT PUMP/AIR CONDITIONER UNIT OUTSIDE MY MOBILE HOME A FEW DAYS AGO A UNKNOWN SMELL COMES THRU ALL VENTS IN AIR CONDITIONER MODE ONLY. WHEN HEAT IS ON THERE IS NO SMELL UNTIL...
This is a condition called Dirty Socks Syndrome air cleaners and dehumidify usually fix the problem also adding a uv light to the duct can remedy the problem the light is probally the cheapest solution
Dometic rooftop air conditioner coil freezeup
We did find a solution, the ducts leading to bedroom in RV was blocked. So far, it has been working since we cleared the way, it no longer freezes up. Thank you.
2helpful
Delonghi Pinguino Classic Portable Air Conditoner Works for 30 min then red light comes on
Have it serviced. It cost me $250 to have a pro do it. Also, check the timer (the dial is hidden by a sliding cover on my unit). My husband cleaned it himself a year later and he took it apart to do it and it works much better now. When he opened it up, it was full of calcium deposit and dust. He told me he did not think the unit had been cleaned properly by the pro.
Top Carrier Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
