How many heating bulbs does a eden pure premier have? I can only see 1 glowing. Also it only blows. Sprightly warm air, even if I turn up the temp.
Posted by Alan pit on
Andrew Taylor
    Top Expert:
  • Heating & Co... Master
  • 35,836 Answers
Seems so be a ceramic element that glows more on the left that the right side. It may be worth swapping out the Heat Sensor for a new one.
https://www.edenpure.com/collections/rpe1500-a5076
They produce a number of models
Posted on Oct 31, 2020
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
Why does my Eden Pure Gen 3 heater blow only warm air?
They have 3 heating elements. Perhaps one or more have burned out. They cost about $32 each.
Aug 31, 2014 | No Clove Leaf Pure Essential Oil 15ml, By...
Electric heater blows cool air unless i turn the thremostat up at least 5 degrees higher then it goes to high and blows warm air
If it's "dual fuel" like heat pump with gas heat, the heat on the heat-pump side won't "feel" warm in the extreme temperatures we've seen in much of the country lately.....2nd stage gas will feel MUCH warmer. If purely electric, 1st stage heat may be off due to a manually resettable high limit switch/ bad heat contactor (giant relay), or a misapplied or defective thermostat. NOTE: if somebody recently painted OR wallpapered, AND it's a mercury-bulb T-stat, It HAS to be level and the connections must be tight!
Jan 28, 2014 | Ruud Central System Air Conditioner
Eden pure starts blowing hot air and then turns cold
I recently fixed this issue for a family member on this exact model, the same issue, it would heat fine for 15 minutes and then cold blowing air would follow afterwards non stop, and when we powered down the unit and restarted it, it did the same exact thing. ( What worked for me ) was ordering a new " Thermostat " which is a white rectangle looking plastic thing with 2 blue wires coming out of it, you can find You-Tube video's showing you how to remove the Eden-pure gen3 cover housing easily, my total cost of this do it yourself repair was just under $20 as of 10/10/14 your cost could vary depending on different factors.
1st...unplug the unit....duh ! lol
Once the housing is removed, look at the top of the unit and locate the 2 blue wires coming out near the front, remove the 2 top screws holding in the thermostat, gently pull out the old thermostat but don't disconnect any blue wires yet, put the new thermostat in facing the exact same way as the old one, re-tighten the 2 screws, next follow one blue wire ( One is longer than the other ) to its location on the block, determine if its the shorter or longer wire, disconnect just 1 wire with a Phillips screw driver, and replace it with the like sized blue wire from the new thermostat, tighten but not over tight ! next do the same for the next blue wire on block.
After thermostat is secure and wiring is secure, put the cover and panels back together......and plug it in and test it again....... Hope this works for you as it did for me.
Good Luck !
Oct 12, 2012 | EDENPURE MINT A3705 Infrared Remote...
Need repair manual for eden pure heaters
The Edenpure Gen4 and US-1000 have a set of 3 - 500 watt bulbs that generate the heat. You'll likely need to buy a new set of bulbs every heating season ($60) or pay an Edenpure service center $100-140 to replace them for you. (Almost imossible to get SCI to cover the the bulbs under their so-called warranty)
Unfortunately, despite the hype printed on the box and Suarez Corporation Industries advertising, those bulbs last less than 500 hours of operation in those heaters. Suarez Manufacturing Industries/Pinnacle Systems have no engineering staff nor did they perform any durability testing on the heaters or any heater components.
Thus you, as the consumer, are stuck with continually the bulbs (in the US-1000 and Gen4 at least).
Apr 01, 2012 | Heating & Cooling
Electric furness blows hot then warm
if this has happened since you got hte furnace it is normal
heres how a heter works
themostte tells heater to turn on
heating element turns on
followed in about a minute by the blower
during the peried before the blower kiks on the elements become supper heated
after the blower kicks on it slowly leves off the element temp and air temp coming out
Jan 23, 2009 | Hunter Fan Company 5/1/1 Programmable...
2001 tahoe front heater not working, rear heater blows warm air
I have the same problem with my 2001 Tahoe. The front blower is working, its blowing strong, but its cold air even with the temp setting as high as it can get. The rear blows hot air. The engine temp guage is at about 210ish which is close to being normal (220). I just replaced the thermostate a few months ago, I don't know if its bad again, or it I deluted the antifreeze too much and it frooze the heater core, or if the heater core just went bad. Any one know what the cause could be?
Jan 05, 2009 | 1998 Chevrolet Tahoe
Heat...
It sounds like the thermostat bulb has moved or the unit is getting an immediate air recirculation due to a partial blockage or air diversion close to the unit causing the warm air to get back to the thermostat bulb too soon, heating only a very small area.
srich
Jan 06, 2008 | Amana PTC153B35AE Air Conditioner
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
