Question about Power Computers & Internet
How to start my laptop yet i have already pressed the power button???
Posted by Eustace Githui... on
  • Larry Ng
    Larry Ng Oct 31, 2020
    so just found a dead PC at a garage sale
    that it(no story told or history)
    step one is new battery and charge it first.
    for say 12 hours.
    then push power button for 10 seconds and release.
    if battery is bad and the purse is too small
    remove it and run on AC power pack alone
    even for ever, no need to charge.
    NO PC told maker nor there model
    no easy answers,
  • Anonymous Oct 31, 2020
    i pc is dead say PC and screen are dead
    if you tell make and model of pC
    read the service tag we can help easy.
    all PCs can be fixed, some tests are easy
    others need shop tools and spares.
    get it fixed in shop like 99% do is best.
    when did the PC last run right.????
    who made this laptop, HP, Dell, Acer,Asus, ?
    and model, all have model number for 40 + years even back to 1983. not one can we guess
    mine is Dell E6540, a better grade LT.
Mikey
    Top Expert:
  • 6,551 Answers
The only way to start your laptop would be to press the power on button!
Posted on Oct 31, 2020
Laptop compaq will not charge will not turn on. Puting charger on it and pushing the on button i see lights once i release on button light goes out. thinking its charger or its where i plug in charger on...
Try this quick fix, if there are no issues with your charger and/or battery, this might work...
- remove battery
- make sure charger is not connected
- long press the power button for about 1 minute
- release then connect charger or power adapter, without the battery
- press power button to turn on the laptop
If this did not help, try using other power adapter.
Nov 05, 2014 | Computers & Internet
Why does my acer aspire e1 571- 6482 not start or charge anymore? only the on led and batt led flash.
pressing power on button should be for 30 to 40 sec but the flashing lights means there is a hardware problem can find flashing light codes on the net you could try removing ram 1 by 1 c if that works hope this helps if not will keep an eye on this
Jul 29, 2014 | Acer Aspire E1-571-6650 Laptop
Dell Studio 1737 --power button is broken. Is there another way to power it on?
friends ... i discovered a way that you can power on the dell studio 1535 easily ...
first of all you know the power button .. it's now working ( or stuck )
in the other side of the labtop, there's a wifi button, when the labtop is already shutten down, you can press it and it will give a light then shuts down the light in the button, that means that it gives power, now to complete the process you should know the touch button in the left side that means Dell MediaDirect ( touch control button of the dell studio ) ..
ok, Now, do exactly what i'm telling you :)
1- when the computer is shutten down, plz press the wifi detector button one press
2- it will give a light then shuts then gives light again for a longer time.
3- when giving the first light for a short time, do not wait, press the media touch button quickly, continuesly and separetly.
it it doesn't work ... try it for many times tell you know when exactly to press the media touch button
then you'll see that the labtop starts as if it was in sleep :)
Feb 10, 2011 | Dell Studio 1737 Laptop
Black screen problem..... start up
The issue might be due to presents of static charges, hence request you to power drain the ntoebook.
Power Drain:
  1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
  2. Remove the battery from the notebook battery compartment.
  3. Press and hold down the power button for about 20 seconds.
NOTE:
Holding down the power button while the computer is turned off drains any residual charge in the capacitors.
  1. Insert the battery and plug the AC adapter back into the notebook PC.
  2. Press the power button to turn the notebook PC back on.
  3. Use the arrow keys to highlight Start Windows Normally , if it is not already highlighted, and then press the enter key.
if persists, recommend you to take the notebook to technician for oniste diagnosis.
Jul 05, 2010 | HP Pavilion dv4000 Notebook
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
I press the power button, the computer beeps 4 times and stops
Please check the battery. You might have to replace the battery bcos it definately gone bad already.
Oct 11, 2009 | HP Pavilion dv6000z Notebook
Adaptor light on. Laptop does not start when power button pressed same problem also when try too start from battery power. Son was playing a pc game and just switched off, have waited for hour still n
try to take out both battery and power adaptor. press and hold the power button for ten secods while both are not connected. then connect the power adapter only. try to turn it on. if it still does not turn on then most likely you have a problem with the hardware. you might need to have it checked out with an outside tech already.
May 25, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Power button problem
There is a small green board underneath the buttons that has silver contacts underneath them that allows the buttons to activate. These silver contacts wear out over time which is why your having to press the power button more then once to get it to respond. That small green board with the silver contacts on them would have to be replaced.
Feb 11, 2009 | Acer Computers & Internet
Eee pc won't turn on (I think have already posted this,not sure)
Sounds like a classic case of hardware failure!!!!!!! possibly your motherboard, start by removing the battery, hard drive and optical drive.
disconnect the laptop monitor and connect the laptop to an external monitor.
remove the memory modules clean the brass contacts with a eraser and place back in the machine 1 at a time to check to see if they work, remember to plug in the AC power suppy, if you see the post screen then its a memory issue and you can then reconnect your laptop monitor to see if it lights up, if everything works but the monitor then its the inverter or backlight that has blown and is easily repairable saving you money on a brand new screen
Nov 13, 2008 | ASUS Eee 4G Notebook
Computers & Internet Logo
16 people viewed this question
Top Power Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
