Question about Fagor Refrigerators
I need to know the cap tube diameter and length for a Fagor QVR-2 commercial refrigerator
Posted by Bob Channell on
Tom Chichester
    Top Expert:
  • Fagor Master
  • 60,183 Answers
Request this information from Fagor.
Posted on Oct 31, 2020
5 Related Answers
Anonymous
  • 2712 Answers
SOURCE: steernig stem diameter
Might I borrow one temporarily from someone for research purposes? It will not be installed in any frames
Posted on Nov 10, 2008
shaun greyvensteyn
  • 159 Answers
SOURCE: ice on cap tube & liquid line, refrigerator not cold
it can be too much gas or a blockage
Posted on May 15, 2009
rtpflh
rtpflh
  • 546 Answers
SOURCE: Frame Specs
1 1/8 inch. to check,make two cuts 1 1/8 inch apart 1'' long in a piece of card board fold back the tab you created,now you have a gauge.ride safe.
Posted on Sep 22, 2009
Genro
  • 85 Answers
SOURCE: I am replacing my brake
The best thing to do is to bring the brake lines with you to an auto store that has costumer service. They can match you up with the right lengths diameters and if it is metric or standard and other connections you may need.
Posted on Nov 17, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My undercounter commercial Fagor FI-48W dishwasher
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
;l';l;l
Posted on Mar 27, 2011
Dear experts. how can i flush the capilair from my refrigerator. some people are using 90% alcohol. is this ok. if it is ok how can i use this. regards. S.Mataw
Usually the capillary tube is blown through with nitrogen or a refrigerant. If you are unable to blow through the capillary tube you can always replace it. Diameter and length are critical. You can find charts through Supco and other suppliers of capillary tubes.
Apr 17, 2018 | Refrigerators
Hello! I need to know the size of the capillary tube because it was broken and now the refrigerator does not reach the freezing temperatures. thanks and please apologize me for my bad english
If you just shortened the cap tube there's your problem. It has to be a certain length to operate correctly. That's why there's a coil of tubing. It is not too long. You'll have to replace the entire cap tube for that model of refrigerator.
Oct 28, 2014 | General Electric Refrigerators
Capillary tube
You can determine this by taking a numbered drill bit index and inserting the proper size diameter but end of the bit into the cap tube. You can then mic the butt end or cross reference to chart giving size of numbered drill bits. The length is also very important when sizing, cap tubes must be as close to exact length as possible. Also cap tubes must be scored with 3 corner file and broken off so as not to alter inside diameter.
Or you could use a cap tube chart. Try www.supco.com
Apply Freon type, compressor HP, temp range of unit, number of feeds.
Aug 24, 2013 | KitchenAid Refrigerators
Need repair manual to fix cap tube on coldtech j6srf61b refrigerator freezer
All you need is the same size cap tube, and coil it the same length as the one that is on there now.
if its typical refrigeration you will need to recover the charge and braise in the new cap tube. Then recharge the unit
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Coldtech J4SRR-40B Commercial Refrigerator
Vt200 wine cooler needs a new capillary tube. Repairman needs to know the diameter and length. The diameter will be some degreenof a 100th of an inch.
Hi
The capilliary can be sized from the outside diameter, the repairman should have a guage to measure it this gives him the internal size from the outside diameter, the length only takes a tape rule, these are normally set to plus or minus 1 inch, so not too critical
Hope this helps
Gordon
Apr 20, 2011 | VinoTemp VT200
The delfield box 18672ptb has no tags andi need to know critical charge
my chart says 32 ounces of R-404 A. Remember, cap tube systems are charged by super heat and TXV systems are charged by subcooling or full sight glass if system has receiver.
Feb 01, 2011 | Delfield 18672PTB Commercial Refrigerator
I've made a 10m water level using two 5m lengths of clear 6mm internal diameter pipe joined in the middle with a proprietary tube connector. I looped the tube with both ends next to each other and the...
The internal diameter is notional and if the two lengths you have used came from different production batches then their average internal diameter along the length of one half may be different to the other. The fact that there is such large ratio between the length of the tube and the internal diameter only makes matters worse.
You need ideally to source a single 10m length and to select a larger internal diameter to maximise accuracy: 10mm i/d will be better but if you can cope with the extra volume of liquid then 15mm or even 20mm will be much more accurate.
Jul 16, 2010 | Plumbing
T-49F
To change out your cap tube you will have to do the following.
Purchase cap tube replacement from supplier.
Recover your refrigerant.
Use your torch to remove the cap tube.
Weld in new cap tube (make sure you have it cut to the proper
length)
Pull a vacuum on the system.
Charge unit with recovered refrigerant.
Feb 03, 2009 | True T-49 Side by Side Refrigerator...
Cap tube
find out the horse power of compresor and freon type. then match that info up to a supco cap tube kit. sizing charts are on back of box.
mitch
northeast cooling
Dec 03, 2007 | True GDM-12 Refrigerator Commercial
True Freezer
Hopefully you were good on cap tube length is this is an important aspect of this system.The length must be matched
May 21, 2007 | True TWT-48 Stainless Steel Commercial...
Refrigerators Logo
15 people viewed this question
Top Fagor Refrigerators Experts
Marvin
Marvin
Arnie Burke
Arnie Burke
Tom Chichester
Are you a Fagor Refrigerator Expert? Answer questions, earn points and help others
