Mitsubishi medallion hd1080. Green light on. Why doesn't it power up?
Posted by Wendi Goldman on
Tom Chichester
    Top Expert:
  • Televison & ... Master
  • 60,180 Answers
Power supply failure
Posted on Oct 29, 2020
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: pinching in at the sides and has blurry rainbow coloring on top and bottom.
Sounds like a pincushion problem. You can obtain the service manual and free diagnostic upport at the following link. Hope this helps.
http://servicemanuals.vstore.ca/
Posted on Feb 03, 2008
Anonymous
  • 25 Answers
SOURCE: color loss on mitsubishi 73" medallion hd1080
TRake the fron grill off and the front board 6- screws on my 65inch there are three adjustment knobs one of them wil adjust the huge
one the whole screen,if not that,I have heard mold growing on and the inside of the blue bulb because it runs the coolest out of the three.
Posted on Feb 10, 2009
Anonymous
  • 80 Answers
SOURCE: green light flashes on my 65 mitsubishi 1080
You need to replace 4 capacitors on the "DM" board. They are 1000uf and 16v. The board is located under a metal shield on the left side of the set (looking from the rear).
Posted on May 21, 2009
mahesh patel
  • 197 Answers
SOURCE: my mitsubishi medallion hd1080 will not turn on.
bad capasitors in power supply they will be bowed on top
Posted on Jun 09, 2009
Anonymous
  • 39 Answers
SOURCE: Moving a Mitsubishi HD1080 Medallion series 55
Actually no just need to HANDLE WITH CARE and make sure you protect the screen,you can cut a piece of cardboard same size of you screen to protected from any object,you TV has mirrors inside just be careful,other then that you will be OK.
Regards
Posted on Nov 17, 2009
Testimonial: "Thank you very much."
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
Feb 17, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Regards
Nov 17, 2009 | Televison & Video
Won't come on
The power board has failed and will need to be repaired or replaced. you can remove this board and, replace individual parts and save a lot of money. You will be inspecting for swollen capacitors and resistors. also, look for discolorations on the board itself.
Feb 19, 2009 | Mitsubishi WS-55807 TV
Color loss on mitsubishi 73" medallion hd1080
Jan 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Medallion power problems.
The set is going into shutdown because a problem has been detected inside. This prevents further damage. It could be anything from a shorted horizontal output transistor to a defective convergence IC. Without examining the board and taking measurements inside, it will be difficult to near impossible to diagnose this remotely. I would suggest that you invest in a detailed repair estimate that shouldn't cost more than $100 and report the results here. With that info, we should be able to walk you through the actual repair.
Dan
Jul 09, 2008 | Televison & Video
Manual mitsubishi medallion hd1080
MY MEDALLION WILL NOT TURN ON THE GREEN LITE IS GOING ON AND OFF THAT SAYS TIMER ON CAN U TELL ME THE PROBLEM.
Mar 26, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Pinching in at the sides and has blurry rainbow coloring on top and bottom.
Jan 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
