Need help with programming of Garrison Convectair wall mount direct wired heater as cannot locate operating manual. Model #052-2025-6 240V 1500W
Posted by Marilyn antle on
Tom Chichester
    Top Expert:
  • Heating & Co... Master
  • 60,200 Answers
Contact Garrison directly to request the manual.
Posted on Oct 29, 2020
5 Related Answers
Anonymous
SOURCE: Replacing a non-programable thermostat for
If you take thermostrat back off and connect the wires together will baseboard heater get hot. If not you may have bad heater. If it gets hot your new tstat may be bad. The way you have it wired is correct. Most line voltage tstats have a ground screw. Your 's may not but will work without one .
Posted on Jan 24, 2009
Anonymous
  • 97 Answers
SOURCE: Need a manual to operate five year old Jenn Aire wall oven
Jenn Aire model tag are usually at the opening of the door, or may have to pull unit out...be sure to check around the door before pulling out.
Posted on Jun 08, 2009
Anonymous
  • 8 Answers
SOURCE: need manual and wall mounts
I don't have a manual for the HGA, but that heater is identical to the ML300HBA, with the exception that it has a black piece of sheet metal that hides the flame.
The manual for the ML300HBA can be downloaded from my website:
http://www.stpaulmercantile.com/ML2030BF.pdf
A wall mount bracket comes with the unit, but if you don't have one, you can call Procom Customer Service at 877-886-5989 or World Marketing Customer Service at 800-776-9425 and ask for one.
Posted on Jun 12, 2009
Don Maggard
  • 3197 Answers
SOURCE: How do you clear and re-enter a new code for wall mounted remote
To change the code you need to locate the smart/learn button which is near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in any 4 digit code you like and press enter.
See if this works for your car.
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxillary, and/or the car door must be shut).
  2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
Posted on Feb 02, 2010
Anonymous
SOURCE: wiring diagram for Dimplex wall heater Model 6100770000
installing a wall mount heater not sure on the wiring .heater has 3 wire black red and blue sources has white and black what wires go together
Posted on Dec 11, 2010
I need to replace power cord on garrison heater model #043-5997-6, my dog chewed it to bits.. what size(AWG) do I have to use? 120v AC 1500w 60Hz
any 10 amp cord will do the job as that is the limit of the power outlet
you can use a 15 amp cord if you can get to fit in the grommet in the case
May 31, 2018 | Heating & Cooling
Manual for garrison oil heater model #043-5863-4
You should be able to download a manual here:
garrison oil filled heater model 043 5863 4
Also please be advised, your model may be under recall due to fire hazard:
http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2013/36781r-eng.php
Nov 16, 2016 | Heating & Cooling
HOW TO DOWNLOAD OWNERS MANUAL FOR GARRISON OIL FILLED HEATER MODEL # 043-5950-6?
Here ya go:
https://www.manualslib.com/manual/906339/Garrison-043-6127-2.html
Sep 19, 2014 | Heating & Cooling
This heater is a 2000 watt garrison convection wall mounted heater. the light is on but the heater does'nt heat up
The heater is disconnected or there is a damaged wire. You can try to open it up or bring it in. I would suggest bringing it in for repairs.
Elisa Jed ' http://www.encoremec.com/about
Mar 04, 2014 | QMark Portable Hydronic Electric Baseboard...
I need to program my garrison convection heater 1500W
i want the spects for the 1500w garrison plug-in convecton heathger
Nov 05, 2013 | Heating & Cooling
Hello i have a williams wall Furnace model#25-35-50. I need to know if its a base board heat and also if you could tell me which wires are which. 1 red and 1 white
What you have is a Direct Vent, Gas WALL Heater. It is normally mounted about 6" off the floor on an exterior wall (since it has to be direct vented out). Not sure what the red and white wires are for, but suspect it's for the optional thermostatically controlled blower connection.
In any event, to help you install this heater properly, I have included a link to the Owner/Installation Manual, which should provide all the information you need to complete the installation correctly.
http://shopfnc.com/pdffiles/williams2man.pdf
You can download and print the manual for future reference.
Feb 26, 2011 | Williams 3003622 Ceramic Wall Mounted...
Open Questions:
My GE window AC Model#AEL06LXQ1 Serial#AM311149P I forgot to add my question. The AC is only a year old/young. It is properly installed in a basement window with ample space outside in the window well which is fully open to the air above the window well is only covered with a window mesh type screen which keeps clean & filters out debris only. Last year around this time it was cooling the entire room nicely however displaying e8 error code intermittently which was a problem. GE refused to advise via phone and set an appt. for a tech. to come over. I did some research and reset, unplugged, waited etc. I have a dedicated electrical outlet for the AC as well. I really do not recall what I did but the unit stopped error coding e8 altogether and worked wonderfully for the rest of the hot season. I cancelled the GE tech. Now this year I am having same problem. Unplugging, waiting, changing settings, resetting to default settings, I have tried everything and to no avail. The AC will run for a while with the compressor in check and cool down the apartment but it doesn't last long, approx. 45 minutes, at best with one or 2 times exception where it held cool overnight. I don't know what to do at this point. I am not too tech-savvy. I also am unable to lift this ac out of the window. I've a back injury and though a relatively small unit, it's too heavy. Please advise. I hope you have an easy fix solution. The user manual doesn't even list the error codes! I have spent hours searching youtube videos and haven't found a solution. Hoping it's as simple as manipulation a setting. Thank you.
Jul 03, 2020 | GE Heating & Cooling
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
