I checked the inlet filter, water pressure and the Washing Machine Dispenser. I saw the red wheel turning without getting stuck. Simply no water coming in Within the 80 second time limited.
Google does indeed know
Miele washing machine error code f63
F63 malfunction: too much foam
If so, there is too much foam in the drum and you may have used too much detergent.Jul 15, 2020
The top 6 errors of Miele washing machines - Coolblue ...
www.coolblue.be > ... > Miele washing machines
Search for: Miele washing machine error code f63
Testimonial: "Thanks. I tried the clean washing before but it didn't work. I also replaced the water inlet unit. Still, no water comes into the drum and F63 error appears. What else can I do?"
' Im Besser ', call Miele Service, if it is the Logic Mainboard, you don't want to buying one of those if it is not the reason. These days, they connect the washer to a laptop and the factory software tells them where the error it.
https://www.miele.ca/en/c/service-and-re...
Their troubleshooting guide says
Display: F63
Water path control unit fault.
This fault is the result of a technical problem that you cannot rectify yourself.
Please contact the Miele Customer Service Department.
What you can do though is look on the mainboard for dry joints, loose connectors or badly soldered wires.
I had two Miele washers, small and a commercial machine and a condensing dryer in an Airport Business Class lounge. They are great machines and highly engineered like modern luxury cars.
