I was asked by my elderly roommate to help diagnose and repair a Visio E65u-D3 LED television.
Posted by Buster Brown on
Andrew Taylor
    Top Expert:
  • Televison & ... Master
  • 34,900 Answers
Have you done the 2 year course and do you have the thousands of dollars of test equipment, meters, oscilloscopes, IC Logic testers and that sort of thing?
Have a read. I wrote this recently
https://www.fixya.com/support/r29790007-repairing_own_television
Posted on Oct 27, 2020
Testimonial: "So what if I buy my replacement parts from a reputable dealer (not ebay)?"
  • Andrew Taylor
    Andrew Taylor Oct 27, 2020
    People buy boards from Shop Jimmy, which is a reputable dealer, but what boards are you going to replace, Power Supply, Mainboard, T-Conn, LED strips? Without the knowledge, it's all guesswork. Unless you can see damage to a board, all the boards will look fine.
    Watch this short 7 minute video. I follow Big Clive, he is an electronics engineer. This the type of hands-on skill you need.
    https://www.youtube.com/watch?v=r2GX2TXw...
How to diagnose television fault?
diagnose television fault Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/167-plasma-flat-panel-displays/1491814-common-diy-diagnosis-repair-info-plasma-led-lcd-ccfl-lcd-tv-sets-monitors-display-devices-mostly-power-supply-repairs.html
How to Diagnose TV Problems
http://www.repairfaq.org/samnew/tvfaq.htm
Latest Repair Tips
Apr 16, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Beplaced the power suppy board. Still have same problem. TV will not go on at all. No White Visio in Completely black. Still no AC voltage readings at ribon connection on ps. What next?
Commonly Reported Vizio TV Problems ' FlatScreenTech.com
flatscreentech.com > Brands
Of course, it is far from perfect and there are a number of things that can go wrong ... If a repair shop does not have all of the LCD TV parts that could possibly be ...
EASY HOW TO FIX LED Vizio TV- no power - YouTube
? 6:13
https://www.youtube.com/watch?v=9xZcTWr2yV0
Nov 5, 2013 - Uploaded by Tampatec
DiY How to Fix led / lcd Vizio TV service repair - no power service repair review guide no red blinking led light, ... I have this TV, however, It goes on, but it shuts off quickly. .... I have a vizioe550vl and it doesnt power up at all.
Fix Power Problems In 5 Easy Steps: What To Do When ...
Jan 10, 2016 | Televison & Video
Visio VX32L has a black screen, appears to power on but picture.
Any swelling on a cap is bad sometime you wont see swelling ontop sometimes its on the bottom, I suggest replacing those caps then try again make sure you discharge the caps as well.
Also make sure its the right caps too!
1000uf 6.3volts or something like that. Ebay a good source for caps and amazon.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Dec 15, 2015 | Televison & Video
Visio tv turns self off
Check the AC power input for any loose contact. Check it with connecting to an other AC input.
Jul 14, 2013 | Televison & Video
I have a 42" Visio
I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the BN_on (on) the backlight inverter and you still have no picture...you will need a new backlight inverter.
Hope this helps! Please rate!
Mar 08, 2011 | Vizio VW42LF 42 in. LCD HDTV
Visio 42in. Plasma TV
The TV is a Plasma, it does not have a "BackLight" as it were, that is for LCD's only.
Vizio are fobbing you off. It will need either a Y-Sustain & Buffers or a Z-Sustain.
Sep 06, 2009 | Vizio P42HD Television
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
