It might be seized. Is it engine driven or is the "engine" an electric motor?
It isn't unusual for a pressure washer pump to freeze in position and electric washers have a facility to turn them by hand using a wrench prior to switching on.
If it was running ok the last time you used it I think it doubtful the engine is seized unless it was at the point of doing so when you stopped it. I suggest you remove whatever must be removed in order to use a wrench and check if a moderate force will get it turning again.
Unlikely as it has a 4 stroke engine. Unless you didn't bother to check the engine sump oil.
Basic maintenance here. Try and turn the crankshaft output with a wrench.
https://www.google.com/search?q=Homelite+pressure+washer
SOURCE: 91 tracker new engine been sitting wont start
1-check for strong battery
2-check for spark from the spark plugs wire
3-check for gas prusser
4-check if there is any after market alarm system build in your car
SOURCE: ran gasoline in 2 cycle engine and it will not
Hello:
Remove the Muffler and Look into the Exhaust Port.
If the Piston has Scratches or Gouges, then the Engine is Trashed and will have to be Replaced.
A New Unit is Usually Cheaper than Buying the Replacement Parts.
You can View a Breakdown of this Unit at the Following Site Addy.
http://www.smallenginepartswarehouse.com/parts.asp
Hope this Helps.
Good Luck
Respectfully
John
SOURCE: miller falls pressure washer pw2hp seized
hi there is a black screw at the bottom of the engine (plastic) if you remove this it is a dip stick. i would also remove the pump from the enging to see if its the engine,gearbox,or pump at fault hope this helps you. any more problems just reply back and i will try to answer your questions regards
SOURCE: Engine seizure
Probably not. You would need to determine which parts were seized up and failing to turn. Whether the camshaft seized before the crankshaft or the rod bearings before the main bearings could limit the damage. But all surfaces should be measured.
If you were to open the motor and remove the timing chain you could manually try to turn the camshafts separate from the crankshaft. If the cams turned and the crank did not, then you could guess that the cams may have survived. Some help, but surfaces should be measured.
The crank being seized would allow further investigation by unbolting the rod caps and trying to turn the crank as each rod cap is loosened. A single rod cap could stop the crank. You would end up grinding or replacing the crankshaft, measure journal clearances with plastic gauge.
So you would be buying the same gaskets, bearings, etc. to do a partial rebuild as doing a better job. The more practical solution is a Salvaged engine for a 14 year old car. A good place to look is Car-parts.com. When you go to this site you will see what I mean.
Your engine is very common. Also, with many Lincolns, older drivers may have low miles and wrecks or other issues which provide good replacement motors. You may be able to get some guarantee.
Rebuilt motors would have a guarantee. With the damage you could have, you would need a "long block". But a complete Salvage engine could come complete with injectors, intake, and other parts ready to go.
