Question about Proscan Televison & Video
By mistake my Proscan DVD Player was unplugged now My DVD Player Remote won't work, is there Codes. I can try, the Remote doesn't turn on the DVD Player or Play the Movies put new battery in it..
Posted by Tom Hogan on
David Spradling
    Top Expert:
  • Proscan Master
  • 11,670 Answers
Try unplugging unit and taking batteries out then plug back in and put batteries in remote
Posted on Oct 24, 2020
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: dvd remote stopped working
open up your remote then separate the rubber / key pads then clean the cercuit using home dry cleaner and leave to dry close your remote gently and its fresh again. reason for this is practice is because moist cause cover between pads and circuit board and thus no contact then no function
Posted on Jul 27, 2007
dennis
  • 79 Answers
SOURCE: parental block princess dvd
This will make the player region free which may also reveal a menue that either gives you the oppertunity to clear the password or clears it automatically...
1. Turn on the Player (with no discs in)
2. Press the Open/Close button (leave it open, like if you were yet to insert a
DVD)
3. Press the Display button (on the bottom of your remote control, close to the
numbers 0-9)
4. Press the following sequence: 1,3,6,9.
5. Press the number of the Region you want (0 for Region free)
6. Turn off and on your player.
Posted on Dec 12, 2007
Anonymous
SOURCE: Lost the manual for programing codes
i need to know how to program the remote
Posted on Oct 25, 2008
Anonymous
SOURCE: I can not find remote codes for the Daytek DVK-5601 DVD player
Well I finally got an answer from Daytek. It's not what I wanted to hear, but thought I'd share it in case someone else runs into the same issue.
"I am sorry to inform you that theres no dedicated universal remote code for Daytek models. However, you can try the code for MTC on our unit and see if it works."
Posted on Apr 09, 2009
Anonymous
SOURCE: dvd player stuck in 'demo repeat mode'
If pressing the stop button on the unit doesn't work, try unplugging the unit for a few mintues, plug it back in, then press and hold the stop button again, that always work.
I agree that this is not the most superior device on the market and sound is average, but it has many advantages that others just don't offer - small size, no complicated cables, unbeatable price and has a very nice appearance, makes all other look like dinosaurs. Untill all others catch up with that, I'm keep this...
Posted on May 10, 2009
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
Remote code for comcast dvr/proscan tv
I was having the same problem with my 40" Proscan Tv. I had to go to Comcast and get the remote with the gray OK button instead of the red. I could program my DVD player with a 4 digit code so this remote worked when I put in the 4 digit code Proscan sent with the TV (0178). This was the only solution I could find . They do have the remotes with the gray button but you might have to be very persistant to get one with the codes for the rest of your electronics.
May 23, 2009 | Samsung DVD-HD845 DVD Player
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Feb 20, 2009 | Proscan 32LA25Q 32 in. LCD TV
Remote
this is from your producer: Product Description ? BASIC OPERATION OK ? everyone knows what a handheld remote control unit does for your home electronics. You can control your basic four (4) components: TV, DVD player, VHS player, Cable or Satellite tuner. Setup is simple for these basic 4? put in the batteries, look up the manufacturer of your component (Mitsubishi TV) and note the possible 3-digit ?program codes?? turn on the component, press the remote control?s PROGRAM button until the light stays red, press the component button (i.e., TV), enter in the ?program code?, and press the ?power off button? ? if the component (i.e., TV) turns off: you are programmed! If the component (i.e., TV) doesn?t turn off, then repeat the sequence using another of the manufacturer?s program codes until it does. Easy ? took me about 3 minutes to program my old Zenith TV (in the bedroom), my SONY DVD player, and my Mitsubishi S-VHS player. No problems at all. HOWEVER, in case you do run into a component for which the ?program codes? don?t work? you can go through a sequence to self-identify the coding. While I won?t go into it here, it is only slightly more time consuming than the other method. As my codes worked fine, I can not address this aspect, so I won?t make a claim we didn?t test.
Jun 06, 2007 | GE HO97685 Remote Control
Televison & Video Logo
15 people viewed this question
Top Proscan Televison & Video Experts
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
