I want to set up for antenna for local channels. I have searched the menu but cannot get correct set up
Posted by Douglas Dutiel on
  • Televison & ... Master
  • 6,197 Answers
First check that the source or input is set to TV (RF) port. Some TVs only have the Source/Input button on the original remote. Others have one among the front panel buttons. If this button isn't on the TV itself and you have an universal remote, you may need to try multiple codes to get the Input/Source button to work properly. Getting the power button to work is often easier.
I hope this helps. Every TV that I've used only displayed the Channel Search when the input was TV. It could be in a Setup menu, under Initial Settings or a Channel menu. Please add a comment with the make and model of the TV for more information on where to find the Input/Source button and the Menu location to for searching for channels. (Note: there was a brief period of HD monitors that were sold as HD-ready TVs. However these units didn't have a tuner. They were meant to be used with a set-top (satellite dish receiver, cable) box.)
Posted on Oct 23, 2020
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Picture is snowy on every channel
If one tv looks good and another one dosent look good or operate correctly then we know for sure that the problem is not the antenna. Now the menu comes up ok because the menu is injected after the tuner into the video curcuit from a osd or microprocessor. sounds like you could have a defective tuner or antenna block assy.
Posted on Mar 28, 2006
Anonymous
  • 3 Answers
SOURCE: TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
Posted on Aug 20, 2006
Anonymous
  • 556 Answers
SOURCE: Stuck on Channel searching!!!
the problem is we have no cable-none at all. The tv is used only for playing DVD's. solution check dvd to tv wire or socket if it is ok then play dvd in another tv if it works fine then problem in tv. for that check tv tuner & its circuit for loose. check tuner itself
Posted on Sep 23, 2007
Anonymous
SOURCE: setup for coby tv-dvd 1350
I need to download the instruction/manual. Can someone direct me?
Thanks
Posted on Oct 29, 2008
Anonymous
SOURCE: DH Channels
is there a setting for hdmi cable on this tv
Posted on Dec 18, 2008
How to use an antenna box for more channels
Once the antenna is mounted and connected to the TV then you can go into setup menu and do a channel search. You will be prompted to set it up as CABLE or AIR/ANTENNA. Select ANTENNA and it will program all available channels for you.
Apr 19, 2016 | Televison & Video
I have a new hdtv antenna and my hdtv gets all the local channels except 8. The direction from my house is 171 and that is also channel 4. I get 4 fine but not 8. what's up?
hello,
There would be weak signal reception at your antenna so it can't get the other channel. So change the antenna direction. If there's no result then increase your antennas hieght means keep your antenna at higher position.
Regards,
Laxman
Sep 28, 2008 | Televison & Video
Program local channels
just search automatically the local channels(scan)on your search mode.click asia pacific region or just asia on your menu.but don`t forget to set it to auto system and the sound for ntsc3.58 system so that you can get clear sound.or your antenna doesn`t install correctly?please check it first
Jan 31, 2014 | Orion1934 19" TV
Model VR-4625 wont pick up any channels with auto scan
Look to see correctly hooked and that in the menu the set is now not set to catv or cable but to air/antenna. If no antenna connected to set or if just indoor antenna you may not pickup on auto search--try to direct enter a known channel with the remote--if you get one you can in the set menu manually add to the memory the set has.
Nov 06, 2012 | Westinghouse LTV-19w6 Television
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
Hi I bought a TD930B GPX today and I already listened music on cd, how I can set up to watch TV channels please give me a little tip? thanks
Since the TV has a digital and an analog tuner, you just need to connect to an antenna with the strength to receive your local channels and point the antenna at the station transmitter (or at least close to the correct direction). antennaweb.org and tvfool.com will both provide some information on the available channels in your area. Antennaweb is very conservative in the list it provides (even with the assumption of an external antenna). tvfool will provide information on the antenna that is most likely to work to get a given channel at your location.
Next set the source to TV and use the menu to search for channels. (Digital channels will only be found if the signal strength is sufficient for the tuner to resolve.)
I hope this helps.
Oct 11, 2010 | GPX Televison & Video
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Mar 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Picture is snowy on every channel. I hooked up my playstation and set it to the correct channel but the screen display is the same. I tried using the menu and the menu comes up just fine. The menu goes on...
Mar 27, 2006 | Toshiba 42H83 42" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
