Question about Whirlpool Ovens
I have a Whirlpool WFG510S0AW0 that gave an error code of F5E1 and started beeping out of no where one day. We tried resetting, setting the self clean but nothing would work so We left unplugged for the time being. When we plugged it back in, the error is gone but oven will not heat up past 215 degrees. Can anyone tell us what the issue may be. Trying to avoid calling a repair guy unless necessary so any hep is appreciated!
Posted by C Rod on
Stin Gola
    Welcome Back:
    Visited the website for 2 consecutive days.
Honestly, it sounds like the control board has gone bad. They are usually not too finicky to R&R, but you have to find the correct part from an appliance parts store. Motherboards for appliances tend to run ~$75 - $200 depending. If you want to attempt the swap-out, first seek instructions on how to test it in place, then on how to remove and replace. If you don't find the manual or directions, and are stuck trying to open it, remove and set carefully aside any parts or shielding then you may see the value in paying a tech for service! Or get a new one....
Posted on Nov 01, 2020
David Spradling
    Top Expert:
  • Whirlpool Master
  • 11,652 Answers
Bad temp sensor that goes from dials to inside oven
3 Related Answers
Anonymous
  • 619 Answers
SOURCE: Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Posted on Mar 07, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Have Whirlpool self clean electric oven model #
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on Jan 20, 2011
mcclave1155
Millie McClave
SOURCE: I have a whirlpool oven
Got this error so I took the door latch in my hand and moved it all the way to the left a few times (it's a bit stiff) then closed the door and started the cleanning button again and whalla it worked like a charm.
Like everyone said it's because of the door latch.
Posted on Nov 15, 2013
What can I do for F5-E1 situation
Check this article as the cause could be the control board, the door lock mechanism or the Membrane Keypad!
Whirlpool Oven Common Problems and Causes
Jan 08, 2015 | Ovens
I HAVE A WHIRLPOOL MODEL NUMBER RF368LXKQ RANGE AND WHEN I TRY THE SELF CLEAN BUTTON I GET F5E1 WHAT IS THE PROBLEM
The F5E1 error codes means that the door light switch OR a switch on the self clean latch has failed. If the oven light comes on and goes off when the door is opened and closed it most likely going to be a switch on the latch thats the problem.
The part numbers are;
DOOR LATCH W10107830
LIGHT SWITCH 3195993
GENE
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
My oven has an error E1 F5. It was working fine until I tried to use the self cleaner. Now the oven and self cleaner will not work . Only beeps when I try to cut it on.
Hey I found your manual and error codes on-line and was surprised that Whirlpool did not have it hard to reach. Click Here=> Whirlpool 30 in Self-Cleaning Freestanding Electric Range Error Codes
Have questions please ask and rate this solution, Thanks Sea Breeze sea_breeze_128.jpg
or greater.
Error codes are on page 61 section 5-1
Please Rate This Solution, Thank You! Sea Breeze
Mar 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Have Whirlpool self clean electric oven model # F368LXKQ. Am trying to self clean-get a F5E1 or FSE1 error code and it will not start to self clean/heat. Any idea what the problem is?
heatman101
Jan 19, 2011 | Whirlpool Ovens
I have a whirlpool oven self-cleaning.. get code F5E1 or FSEI, when i set the self cleaning?
I live in apartment with a Whirlpool dishwasher and oven. Today was my first day to do automatic clean. After two minutes the "F5SEI" would pop up, then the door would unlock. I repeated this a couple of times. My mind wondered about a water source; perhaps the dishwater. Fortunately, I had a load of dishes ready to go. So I started the dishwasher, then the automatic clean on the oven. Behold! They work together like homies :)
Nov 15, 2010 | Whirlpool Ovens
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My oven code is F5E1 , my oven was in self clean , now the door is locked
F5E1 is door latch assembly. One way that may work to unlock is to turn circuit breaker to stove off for few seconds then turn back on and door lock should activate and unlock. If not you are going to have to replace the door lock assembly.
Mar 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Error F5E1 after self cleaning
Hi There
I have read the codes you are looking for,so I'm sending them to you and i hope this will help.
F5 E1 16 Door latch not operating Check that door switch is completely closed. Check latch, solenoid, and actuation switch for electrical or mechanical malfunction.Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Ovens Logo
13 people viewed this question
Top Whirlpool Ovens Experts
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
