Question about Enzer Lands Phones
Looking for manual for Enzer Eurosat 3000 cordless phone and Base Station
Posted by Harry Bartelink on
Andrew Taylor
    Top Expert:
  • Enzer Master
  • 34,956 Answers
Tom Chichester
    Top Expert:
  • Enzer Master
  • 60,292 Answers
Contact Enzer directly to request
Posted on Oct 29, 2020
I not have manual for Uniden dect 6 cordless phone on my phone I can't get any dial tone,I think I pressed a button on the phone either mute, intercom or redial, how to reset phone
If you have no dial tone the problem is most likely the base station has failed, nothing you can do will kill the dial tone (no button you pushed etc.) except a failed base station.
Dec 19, 2016 | Uniden DECT 6.0 Cordless Phone
Panasonic KX-TCD25AX cordless phone. Why can't it find the base station?
several reasons
too far away from the base station
too much interference between the phone and the base station ( buildings, iron sheeting etc)
the phone is not programmed into the base station memory-- re do the system program where the base station recognizes each phone and sets it's number for identification
May 14, 2015 | Panasonic Lands Phones
I require manual for Logik cordless phone
It is hard to find manual for a phone using the serial number of the base and hand units. Please check if the Logik phone is one of these models
L15DTAM10
L25DTAM10
L35DTAM10
The manual for these can be loaded from
http://documents.knowhow.com/Audio-Mobile%20Phone-Satnav/L15_25_35DTAM10_IB_A6_final100804_running%20change2.pdf
Aug 21, 2014 | Lands Phones
The lights on the base station are not working. Yes, I have checked the owners manual.
The power supply of the base station is working correct? the cable from the power supply is not broken? and the cable from the power supply is inserted?
Just a few questions, things I would start with when my base station wold not have any lights.
Oops the base station of my Siemens Gigaset S79H does not have lights.
Jul 22, 2014 | Siemens Gigaset 8825 Cordless Phone
I have the swatch cordless II phone with base station however I have lost the instruction manual for the base station and therefore cannot register the handset with the base station. Has anyone got a...
To register a handset with Cordless 2 base: Keep pressing call button [loudspeaker icon] on base for 5sec. then press [right pointing arrow in a diamond] twice. Then 9 0 1 then the system PIN if required. Choose internal number 1 to 6 for this handset and then the designation of the base station A=2, B=5, C=8, D=0, followed by [right pointing arrow in a diamond].
Hope that helps!
Jan 17, 2010 | Lands Phones
I have two newly refurbed units that keep scanning, but won't pair to the base. I have done everything the installaton manual says but I must be missing something or the base unit is defective.
Depending on the base station that you have, the base station may only accommodate from 1 to 4 - (T)7406(e) sets.
Is there more than one link to the base station, meaning have you programmed new sets, and have these new ports from the norstar been attached to the base station.
1 port = 1 phone. You can see on top of the base station if there are more jacks that you can plug your ports into.
The T7406 sets are digital sets, meaning that they require their own extension numbers, but afterwards you can program Answer DN's to the sets, making each set capable to answer any other phone.
Sep 10, 2009 | NorStar T7406 Cordless Phone
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
My house phone keeps saying bs search and wont call out or recive calls
bs meaning of course - Base Station...
There is no link between your cordless set and the base station, hence the message.
I would do what SpencerR stated, try to re-establish the connection via the base station to accept the handsets again.
Have the cordless sets worked before?
It may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless sets, and take out the batteries in the cordless set. Wait for about 15 seconds for all the power to drain out of the sets, and re-install the batteries.
This forces the base station to re-establish and link to the cordless sets.
Good luck
May 11, 2009 | Lands Phones
E4 code on base station
i know that you dont want to hear this but that means it must be replaced. you should be able to get a replacment form where you purchased the phone
Dec 29, 2008 | Uniden TRU9480 Cordless Telephone
Audioline cordless phone
answering machine not working on the base station
Jan 13, 2008 | Philips CD6452B/37 Twin Cordless Phone
Lands Phones Logo
13 people viewed this question
Top Enzer Lands Phones Experts
Marvin
Marvin
k24674
Are you an Enzer Lands Phone Expert? Answer questions, earn points and help others
