Question about Home
Ok I really need help from someone please.. I recently had a flood in my basement due to a broken pipe underground from the next doir neiighbor. Ever since they had it fixed my water pressure goes to almost nothing throughout my entire house but my upstairs shower is making a loud annoying squealing sound & it happens 2 to 3 times every time i take a shower. Is there a way i can pist a video of the noise on here?
Posted by Andrea Cannon on
  • Andrea Cannon Oct 21, 2020
    https://youtu.be/q34VTKHxhtE
    That is the sound that my shower is making and uts so annoying. I had a pkumber come out here & he said i needed a bigger water line but I never had this problem until the water department had to dig up the street to fix my neighbors pipe
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Home Master
  • 37,161 Answers
I would bet that theres a blockage in the pipes somewhere. dirt rock? who knows
Posted on Nov 07, 2020
ray gallant
    Top Expert:
  • Home Master
  • 70,814 Answers
FILE A LAW SUIT AGAINST THE WATER COMPANY AND YOUR NEIGHBOR
5 Related Answers
Anonymous
SOURCE: horrible noise
it is the color wheel i have a similar problem and am looking for the part, the color wheel is a small electric motor that spins at a high speed and it can go bad. which will lead to the horrible squeel/hum/buzz.
Posted on Apr 24, 2007
Anonymous
SOURCE: Buzzing loud noise constantly.
I HAVE A RCA 50 HDTV DLP MODEL #D50LPW134 IT MAKE A BUZZING SOUND AND NO PICTURE i CHANGE THE BULB AND STILL NOT WORKING.
[email protected]
Ken
Posted on Jan 10, 2008
Anonymous
  • 11 Answers
SOURCE: hissing noise in house
To solve this you are going to need to start eliminating things. You say you hearing is good, well just make sure next time you hear the hissing put your fingers in your ears to make sure it goes away. If it doesn't then it is internal i.e you have tinitus.
Next start turning things off at the mains. Your hifi can't hiss if it has no power, so try turning it off at the mains by unplugging it. If it is not your HiFi then start turning other things in your house off. Till you stop it.
Regards,
Andrew
Posted on Sep 14, 2008
Thomas F. Schneider
  • 2715 Answers
SOURCE: hot water faucet makes loud noise when first turned on
Fix Ya, then?
Posted on Mar 19, 2009
Chi Chu
  • 8457 Answers
SOURCE: TV has started making a really loud buzzing noise,
It the colors wheel,the fan don't make that much loud of a noise.When the colors wheel spins off it axis it make very loud squizzing and buzzing noises.
Posted on Apr 04, 2010
I have a Everbilt #EFLS10-HD PLASTIC LAWN SPRINKLER PUMP. That losses prime when it shuts off. Also to operate garden hose must have sprinkles on. Please HELP... I do not have my own well so really don't...
Sounds like a broken or cracked hose underground. Check for wet or soggy spots in your yard. Isolated leaks can happen on piping like this.
Hope this helps.
Feb 04, 2018 | Garden
RELAINCE 606 GAS WATER HEATER. WE RECENTLY HAD THE BASEMENT FLOOD DUE TO ALL THE RAIN. WE NOW HAVE NO HOT WATER, I AM SURE DUE TO THE FLOODING, BUT CANT GET THE PILOT LIGHT RELIT! HELP
If keeping the thermocouple bypass pressed keeps the gas flowing to the pilot but the flame goes out when it is released in spite of keeping the flame going the customary amount of time, then either the flame isn't powerful enough to reach and heat the thermocouple bulb, the pilot flame or the bulb is out of alignment or the thermocouple is faulty.
If the flame is weak it indicates a blockage in the jet or the supply pipe.
Sep 08, 2017 | The Kitchen Appliances - Others
GE Gas Dryer DDG8280SAMWW runs, but does not heat. We had a minor basement flood (thank you, Hurricane Irene!) with about 4" or so around the dryer. We do not hear the "whoosh" that would...
Sorry to hear about the flooded basement ..here in Virginia i only had a couple trees down and power go off for 12 hrs but no flooded basement.
Their is no way to clean/clear the igniter persay..gotta check and see what shorted out due to the flood...this tip i wrote explains what to check on gas dryers when they dont heat. http://www.fixya.com/support/r10293028-gas_dryer_not_heating
Good luck i hope this help you to figure out why your dryer isnt heating,
GENE
Aug 31, 2011 | GE Dryers
Machine was in a flooded basement recently and wont start,what to do?
change the water pipe or call the plumber please i badly need a rate for my answer i am a student and i did many research for this so please rate my answer : )
Aug 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What can I do to assure that my commode won't overflow? I came home after being away a week, and my basement was flooded due to the upstairs toilet leaking. Plumbers say it was just clogged. It totally...
Turn off the water at the valve going to the tank of the toilet. The valve is normally located half way between the tank and the floor, on a pipe leading to the tank. The water in the bowl will last over a week and should not be a problem. Good luck, I hope this helps Please rate me, Thanks
Dec 30, 2009 | Crane Plumbing Toilet To Go Tall...
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Leaking out of the bottom
The water drainage pipe is probably tampered. You need to replace it. Take apart the washing mashine and find the drainge pipe. If it is not tampered, some pipe is loose or broken in the washine mashine. If all this is too hard, call a repair man to fix it.
Apr 07, 2009 | Washing Machines
Home Logo
15 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
