My TV made a loud pop and tripped the fuse box, there was a burnt smell but when I tested all sockets and plugs they work fine as does the TV. Did it just over heat as it get warm all the time
Posted by Robert hanlon on
Dariusz Zalewski
  • Televison & ... Master
  • 1,034 Answers
Usually loud pop signal blown capacitor
Posted on Oct 21, 2020
  • Robert hanlon Oct 21, 2020
    Is it dangerous the TV still works. Thanks for answering
  • Dariusz Zalewski
    Dariusz Zalewski Oct 22, 2020
    If still works means is not dangerous. It could responsible for something what you dont use too often like audio output etc or filtering capacitor on power supply, backlight and more
2003 ram2500 5.7 hemi wont shift from 2nd to drive or overdrive
The shift linkage could have come undone or be damaged (hence the pop sound) also could be an electrical fault (fuse making a pop sound when it fails)
Feb 08, 2014 | Dual 03-09 Dodge Ram Quab Cab 2500 3500...
Fuse rx 570 pioneer stereo
Sounds like you have a much bigger problem than just a fuse. Popping sound and burning smell means something much more serious.
Jun 18, 2013 | Audio Players & Recorders
Blown fuse but appliance still works
There may be a short AROUND the fuse. Kinda rare but it does happen.
Nov 22, 2017 | Beko Wm & Wma Models Washing Machine Motor...
Tv when plugged in trips main fuse box
If there is a short circuit inside the TV, the fuse should normally blow first before tripping your breaker. The only exception is if you have a short in the ac cord or the line filter of the TV set. Have you tried the tv on another circuit to see if it trips that breaker? If not, it could be that your first circuit is close to an overload and the TV is simply pushing the circuit "over the edge".
Sep 02, 2012 | Televison & Video
My cooler just stop after spark on the socket it was working fine now i change the wire but it dont turn on
check the fuse in the plug. check your fuse board also. a circuit breaker may have tripped down, or you may have blown a circuit fuse if its the really old type. plug in another electrical device to check.
May 21, 2012 | Refrigerators
Tv made loud popping noise when turned on now doesnt work
The problem is with the voltage capacitors and transformers on power circuit board.Some of them has burnt off and so only you are having this smell and popping sound.You have to take voltage readings and test power supply components such as bridge rectifiers and capacitors. If there is no voltage rating you need to replace that part if not you have to check the soldering joints and solder it again.
Apr 27, 2010 | LG 42PC3D 42 in. Plasma Television
TV popped when turned on
My sons tv did the same thing, 3 trips by the repairman before they finally replaced the "brain" Works fine now
Dec 25, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
