Question about Electrical Supplies
I would make and use one if at all possible. the life you save might be your own
Posted on Nov 27, 2020
Yes! All generators should be grounded. If they are not it can create static around the generator and in the tank which could cause an explosion.
Also if there is a fault in the alternator or wiring it can make the Generator itself a live feed. Resulting in electrocution if someone touches the generator. We have seen this more than once.
If you need any other advice please let us know. We are always happy to help. https://www.generatorguru.com/need-help/
In the states, a portable generator that supplies ONLY equipment mounted on the generator and/or cord and plug-connected equipment THROUGH RECEPTACLES MOUNTED ON THE GENERATOR do not require bonding to a grounding electrode.
Posted on Oct 20, 2020
The coil is bad, you will need to replace it
Posted on Oct 12, 2014
Testimonial: "You do not always receive the help you hope for. In this case Kelly was good enough to respond, I am grateful to him, and his expertise."
Jun 06, 2017 | Electrical Supplies
Mar 23, 2017 | Electrical Supplies
Jan 12, 2015 | Computers & Internet
Oct 12, 2014 | Electrical Supplies
Sep 09, 2014 | Moen T951 Monticello Two-Handle Low Arc...
Sep 09, 2013 | Motorcycles
Jan 13, 2013 | 1996 Jeep Cherokee Sport
Dec 16, 2012 | Kohler Generator 20kw 20res W/ 200 Amp...
Nov 05, 2010 | Garden
15 people viewed this question
