Question about Freezers
Emerson chest freezer not getting cold and making clicking sound what do I do
Posted by Michael Hurston on
Andrew Taylor
    Top Expert:
  • Freezers Master
  • 34,896 Answers
Clicking sound is overheat at the compressor. There is a device called a Clixon that is cutting and restarting. Remove covers and clean the condenser grill with a vacuum cleaner and brush.
Posted on Oct 18, 2020
The freezer is running but will not get cold enough to freeze food.
Sounds like you need to get the engineer out. If not getting cold its a manufacturers problem
Dec 12, 2010 | Magic Chef 12.2 cu. ft. / 345 liter Chest...
Freezer motor clicks on but then clicks right off again
Make sure the condenser coil is clean and the fan works (if not replace it) If those are ok probably the compresor relay is bad (no more than $30) and after you replaced the relay ,if still the compresor won't start the problem is the compressor itself.
Aug 27, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Chest freezer motor runs but the inside doesn't get cold
Sounds like you have a bad compressor or it has lost the gas charge.
Aug 05, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezer temp
Coolant is leaking (because it is probably old), so you might want to get a repair person to get some more coolant, or you could just buy a new Freezer.
Apr 08, 2008 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Freezers Logo
14 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
