Question about Smeg Kitchen Ranges
I've got a smeg oven and the center burner won't light the igniter does spark but won't like and I have no idea what's wrong it seems like the gas is not getting to it and I don't know why. Please help.
Posted by Trent Hall on
  • The Spaminator
    The Spaminator Oct 17, 2020
    Hi Trent Hall, I want to help you with your question, but I need more information from you. pull the burner off the stove and look to see if there is a small hole in the burner it is probably clogged with grease or debris. Use a pin to unclog hole. look on youtube for burner on smeg not lighting.
    that is where I remember seeing this as I have a similar problem but in my stove it is most likely the spark connector to the burner.
JonSnell Electronic
    Top Expert:
  • Smeg Master
  • 32,496 Answers
Try cleaning the burner and jets.
Posted on Nov 05, 2020
5 Related Answers
catriver
Ron Marek
  • 878 Answers
SOURCE: No Spark to light burners
John, is this a 790.73053? Catriver..post back.
Posted on Nov 19, 2006
Anonymous
  • 130 Answers
SOURCE: Thermadore gas stove top - left 2 burners won't light
Either the potentiors or the simmer control.
Posted on Jan 06, 2008
Anonymous
SOURCE: Tappan gas stove,oven not lighting
i am unable to use my oven on my tappan gas range. every other part of the range works wonderfully. the oven just will not light
Posted on Sep 11, 2008
erica graber
  • 530 Answers
SOURCE: Maytag MGR6775 Gas stove. One igniter not working.
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
Posted on Jan 04, 2009
Dennis Boxerman
  • 1305 Answers
SOURCE: Oven burner will not ignite
http://www.southbendnc.com/downloads/manuals/500SeriesManual_1188716.pdf
try this web site for operations manual.
Sounds as if the thermocouple may be bad. It is enough to keep pilot lite but not enough to open safety valve. Some of their ovens have a "Mercury Switch" instead of a thermocouple. Look behind the kick plate. It will have a white ceramic base and have 2 wires going to it. The end sits in the pilot same as thermocouple. If there is a pilot valve, make sure that once the pilot is lit, you turn it to "on" if the position is available. Lots of options on these ovens as they custom build alot for certain companys. Check this out and let me know.
Posted on May 23, 2009
THE GAS OVEN DIES WHEN YOU LEAVE KNOB
are you turning it after it lights before releasing the knob
pushing it in starts the piezo spark but turning it lets in the gas
Jul 15, 2016 | Smeg C6GGXU 24" Freestanding Gas Range...
Smeg 90cm burner tha lights up and goes off as soon as you let go the knob
For the oven burning cakes check the oven tempeture sensor for the top burner issue would check the igniter harness and the the igniter modules on the harness as well sometimes called spark igniters or infinite switches
Mar 07, 2015 | Smeg Ovens
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
One of my igniter in my smeg gas cook top does not spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 30, 2011 | Smeg 23 in. SE64 Gas Cooktop
Nothing happens with the ignition, no spark at all. I now have to light hob with a match
heatman101
Sep 16, 2010 | Smeg S300X Electric Single Oven
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
My smeg cooker is brand new! after cleaning it - one of the rings will not ignite properly, it clicks so gas is coming through but no flame! any sugestions?
Brand new means you have a warranty, get the service agent to check.
I have found that you can easily place the wrong burner cap on the incorrect burner ring(the smaller burner caps).
Could also be dirt or water in burner ring or the burner jet(use needle to clear jet).
Are sparks coming from all ignitors? You might have damaged the spark plug.
May 01, 2010 | Smeg 23 in. SE64 Gas Cooktop
Kitchen Ranges Logo
13 people viewed this question
Top Smeg Kitchen Ranges Experts
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
