This message means that a water sensor in the base of the washer has been tripped. This usually means that there is a leak in the washer. Sometimes, the sensor is faulty. Turn off the washer. Turn of the incoming water lines at the shut off valve and unplug the washer. Tip the washer forward to allow any collected water to leave the area under the unit. Check the tub where the drain hose connects and incoming water hoses for leaks. Check for any problems with the drain pump or the hoses to the pump and drain. Replace or repair these items. You might just need new washers or hoses. These steps apply if there is water in the base of the machine and the tub is dry. If the water flows into the washer when you plug in the machine and turn the water shut-off valves to open, replace the inlet valves that has failed in the open position.
If the washer tub has water in it and there is no water in the base from a previous leak, check the water leak sensor for a short. Check the wiring between this sensor and then control board. Check the triac for the drain pump and the pressure switch and level sensor for this pump. If the pressure switch and level sensor are okay, then replace the controller.
Some of the parts for the AWM 6122 are available here: https://www.4whirlpool.co.uk/awm-6122-857061212203/catalogue.pl?path=600169&model_ref=13246411 . I hope this helps.
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
SOURCE: Whirlpool AWM 8103/1 error FP
it looks like you have a clog filter or pump issue.
take a look at this forum
http://www.howtomendit.com/answers.php?id=53072
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06
Drive
Motor Tachometer Error
The
control is unable to properly detect motor speed and the
machine will shut down. If a failure occurs during high-speed
spin, the door will be unlocked after 3 minutes.
Thank you for writing to fix ya.
Best regards Richard
