Question about The Video Game Consoles & Games
How to install the battery in Citizen Wingman C080, what is the position of the spring?
Posted by niktchobanov on
Mario Kneevi
  • 3 Answers
I believe this video will be useful.
https://www.youtube.com/watch?v=-X1wsJF61iw
Posted on Oct 23, 2020
When I plug in my Wingman (win 7-64) and I get the B.S.o.D. and windows has to reboot. any ideas? Im sure my driver is compatible for the system
I have Win7-64, and able to run Wingman. If you have the CD, it is okay, you can install both the joystick and USB drive, but the better option is that you go to the Logitech site, and download the latest drivers for the Wingman. Wingman is the older version of 3D, but the drivers of Logitech extreme, 3D are workable with the old Joystick Wingman., and they should work well on the Window 7 , 64 version
May 03, 2014 | Logitech Extreme 3D Pro Joystick
How to re-install battery in Citizen B020 ladies
The Eco watches do not use a conventional battery.
Rather they use a re-chargeable 'accumulator' instead The size and type varies by calibre but the B020 is as below:
Original Citizen Capacitor Battery 295-76Battery Size: MT516
Dec 13, 2012 | Citizen Watches
Have fitted a new battery but no joy, any tips I can try?
mcdevito75 here, Some quartz watches and I believe Citizen is on of which need the exact factory number battery installed / replaced. if you did use the exact battery number and the new battery is not working, remove the battery and carefully clean the battery contacts with a Q-tip and rubbibg alchohol do not soak the battery contacts just clean them. Also your new battery could be dead, who knows how long it was on the store shelf. Alaso wipe off any oil from your fingers on the new battery before you install it in the watch, make sure the battery is seated correctly in the watch, the back cover may also have to be installed back onto the watch to complete the battery circut for the watch to work. If all this fails you can try to contact Citizen online, Contact CitizenWatch.com and get their recommended battery size for your watch, OR, look for a small watch repair shop in your area. One Last thing, Your Citizen watches Quartz mechanism could also have gone bad, in this case you"ll need a new watch.
Feb 11, 2011 | Citizen Watches
How do i set up WingMan Extreme
Hi Cat,
You will need to install LGS ( Logitech Gaming Software ) to configurate this hardware, you can find it here:
http://www.logitech.com/en-us/486/2964?WT.z_sp=Image
Thanks and have a nice day
J -
Apr 04, 2010 | Logitech WingMan Extreme Digital 3D...
I have citizen navihawk and the alarm chime is not working. What could be the problem??
Did this start after you had the battery changed? It is not uncommon for the alarm contact spring to get broken off that way.
Feb 15, 2010 | Citizen Blue Angels Skyhawk Watch
I can't uninstall Wingman 4.10
Try a Windows system restore to the date before you installed the Wingman 4.10.
It may ask to install the Wingman 4.10 again, but use the program uninstall. If you have to do the windows uninstall again, then what you can do is look into the startup by typing msconfig.
Disable the startup program that you uninstalled.
Aug 20, 2009 | Logitech WingMan Extreme Digital 3D...
Setting a Citizen Chronograph watch
assuming the battery isn't dead (IF IT IS DON'T TAKE THE BACK OFF, YOU WILL LOSE THE SPRING THAT MAKES THE ALARM SOUND) the button on the bottom right click it until the function selector is pointed to time, then pull the button out, then the top two buttons i believe change the hour hands. before setting the time you will need to zero this watch out, or calibrate it or the date will not change in synch with the time at midnight.
my battery is dead and i am a truck driver and am therefore having a difficult time (no pun intended) finding a place i can get parked to have my battery changed. please believe me when i tell you that you will lose this spring, a jeweler lost mine once and it took months to order a new one
Apr 10, 2009 | Citizen Watches
Citizen C080 Setting year
Find equivalent calendar years to substitute for the current one!
For example, 2010 = 1993 = 1999
2012 will be a problem, but for the most part, correlations exist within the programmable range.
How to find them? PERPETUAL CALENDARS:
http://www.vpcalendar.net/Year_Correlations.html
There, now get back to practicing your slide rule skills!
Mar 13, 2009 | Citizen Watches
Video Game Consoles & Games Logo
Top The Video Game Consoles & Games Experts
Jun Salazar
Level 1 Expert
Marvin
Marvin
Lawrence Oravetz
Are you a The Video Game Console and Game Expert? Answer questions, earn points and help others
