Does a PIONEER sterio receiver SX221R have a remote control . this unit was given to me , so i don't know if origionly it had a remote and where can i purchase one if it did. cheers chris
I also have the VSX D412 and DirectTV. My DirectTV remote controls the D412 fine, but I did have the same problem you're experiecing with a Sylvania flat screen that the remote wouldn't operate. I corrected my problem by turning the TV off, then back on using the TV's remote, then telling the DirectTV system that I didn't know the model number and let the system search for the code. Hope this helps.
check your remote. try fresh batteries as well. if it still wont work, try opening your remote and clean it with a soft bristle brush or the like. try testing it again.
Of course it does. No complex modern A/V electronics exists without a remote. They save money on front-panel indicators and controls my requiring a TV and a GUI to operate, too.
You mean Vsx 405, right? Model numbers are senseless enough without typos.
Are you saying you DON'T have a remote? How did you ever set it up? There are several CU-VSX105 remotes available on eBay, one at $9.99 and expiring in a few minutes (17:12 PDT). If you get this in time you could snipe it at the last 10 seconds.
Many a Pioneer receiver will come up MUTING if it powered down Muting. It's not clear if you have been experiencing unwanted shut-downs. Unwanted Muting or any other command could well originate with an unintended remote control source. Mask the receiver so it can't see other I/R sources.
hi,
You have to order for the IR receivermodule for the system. Also check inside the frond panel of the system is there is any durstaccumulated in frond of the IR receiver unit.
ok
I have the same unit. It does come with a remote. The original remote is pretty much impossible to find. But also there are some companies that sell remotes for it. Google Pioneer VSX403 remote replacement. I have yet to get a remote :D Good Luck.
First you need a stereo that has the remote control option or you can purchase an interface from PIE (Precision Interface Electronics). This will work only if you have a remote for your pioneer. Let me know what kind of Pioneer you have and the Make, model and year of your car and I can even find you the best solution. But you also should be able to go some where such as you local car audio shop, best buy or circuit city. Good Luck.
-Andrew Hawkins
