Hi everybody I am looking for a replacement remote control for a Warmlite WL45033N fireplace! Can you advise?
Posted by Abdelraouf Ajaj on
Naheed Mir
    Habit-Forming:
  • 159 Answers
If you are looking for a replacing remote control for a Warmlite WL45033N fireplace, then I will recommend checking DIY; they are offering an Electric fire replacement remote control.
Posted on Oct 14, 2020
  • Abdelraouf Ajaj
    Abdelraouf Ajaj Nov 09, 2020
    Thanks for help
    I went to B&Q and they said that the universal remote control is out of stock for a while!!
    Thanks
2 Related Answers
Paul Carew
  • 3527 Answers
SOURCE: remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Posted on Dec 13, 2008
Rich Landrum
  • 4736 Answers
SOURCE: I just replaced the batteries in the remote
You didn't mention how many batteries you replaced. If it was only the 3 (AAA) in the hand held remote, you have 4 (AA) to go in the remote's receiver. It's the black box, inside the fireplace.
Depending on how long the batteries have been dead, the remote may have lost it's privacy/frequency code. In which case, it can be reset.
here is a link to your Owners Manual http://literature.mhsc.com/ambient/manuals/RCMT.pdf in case you have misplaced yours. You can download and print it, if you like. It will walk you through how to reset the privacy/frequency code. It has a Trouble Shooting Guide, that can prove invaluable.
Also, make sure the pilot on your gas logs or fireplace is burning and the Control Valve Knob is turned to the ON position. If it isn't, the remote control will not work
Hope this helps solve your problem.
Posted on Feb 26, 2011
How do I get a replacement remote control for fireplace
Look inside the fireplace to see the brand name on the log. Call the manufacturer. There may even be a number on the metal plate with the manufacturer's name.
Mar 03, 2015 | Heating & Cooling
How do I resync my ProCom remote with my ProCom Vent Free Fireplace? I have an older model, SSU320RHL-GB.
I ran into this same problem yesterday while I was trying to get my used unit up and functioning.
If you don't switch from pilot to off and wait about a minute before turning it to the "electric" mode, the remote will NOT light the unit.
Oct 24, 2014 | Procom SSU320RHN-GB Heater
Temperature control
If you go to this website they can assist you with getting technical assistance on diagnosing your issue and getting a remote for you. Hope this helps. http://www.rick-horwath.com/Whalen_Windham_Combination_Electric_Fireplace_Heater_Manual.pdf
Dec 26, 2013 | Whalen Furniture Windham Fireplace TV...
Ambient remote control 5884 won't turn fireplace on and off
  • Make sure your valve is in the "on" position and not "pilot".
  • Install fresh batteries in both remote and receiver (remotes are finicky about good batteries.
  • Ensure the switch on your receiver is in the "remote" position.
  • Follow manual to re-sync handheld to receiver if necessary.
  • A burner not lighting could also be the fault of the appliance (bad thermopile). Check this too, and replace if needed.
  • Replace remote if necessary: Universal Fireplace Remotes
Dec 28, 2012 | Ambient Tech. Rcmt Manual Fireplace Remote...
Skytech 3301 thermo
Check to make sure your thermostat is set at a temperature that will turn the fireplace "on".
Double-check what your "swing" temp settings are set at, as this may effect how quickly the unit shuts off because it thinks it's too close to the target temperature.
If needed:Skytech's Tech Support number is 1-888-672-8929They are available Monday to Friday, 8am to 5pm EST.
If your remote needs to be replaced, the 3301 is available here:
Skytech 3301 Fireplace Remote
If you are looking to replace it, I would also highly recommend looking at Skytech's new 3301P2 remote. It adds a programmable thermostat, and a much nicer back-lit LCD screen. This unit is available here:
Skytech 3301P2 Fireplace Remote
Dec 15, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
Cant start gas fireplace
  • Find the remote's receiver under the fireplace.
  • There should be a switch to change from "remote" to "ON".
  • Turn the switch to "ON", if the fireplace ignites, you may need to re synchronize your remote. If it does not, your remote control may be bad.
  • Bypass the remote to ensure your fireplace is operational by connecting the "TH" and "TP/TH" terminals on the valve with a wire or paperclip. If the fireplace lights up fine, then it is for sure a bad remote.
  • Universal gas fireplace remotes can be found HERE.
Oct 28, 2012 | Empire Comfort Systems Empire Tahoe...
I just replaced the batteries in the remote control for my Ambient fireplace and now the remote is not working
Feb 26, 2011 | Ambient Tech. Rcmt Manual Fireplace Remote...
I have a Town & Country fire place with a MAESTRO Control System which includes a wall control and hand held remote. There is a red light flashing on the bottom of the wall control under what appears...
Hi
behind the wall control there are 4 AA batteries that need to be replaced. you have to remove the wall control plate with a screwdriver and the batteries are tucked into the wall behind the wall switch.
ps - my husband is an electrician and he wired the fireplace but forgot that there were batteries behind there! it was me who asked for the screwdriver. ha!!
Dec 25, 2009 | Grilling
Remote control working with fireplace.
Dec 13, 2008 | Dimplex DS5603 Heater
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
