Question about Miele Dishwashers
Hi
Intake/Drain light flashing means an issue while draining. The
dishwasher is not draining properly. Please check for air gap on the dishwasher
is not clogged. It prevents dishwasher from draining properly and sometimes the
drain flow is restricted due to gunk. Cleaning or bypassing the air gap will
resolve the issue. If this doesn't resolve the issue then it is due to seized
(or stuck) drain pump. Keep handy large bowls and towels to soak the water out.
Disconnect the power to the dishwasher or turn off the breaker to the
dishwasher. Tip machine on its back; remove screws that hold the bottom tray
on. Remove the hoses to the main motor, remove electrical connections and
switch it on. If the error still appears then turn the rotary selector switch
to "Stop/End" or press the "Start/Stop" switch for approx.
5 secs to cancel the error message. Switch the appliance off and then back on
again. Hope this helps...please post back for further assistance.
Daniel
