Question about Maytag Refrigerators
Came home and my ice is melted. Freezer is 46 degrees and fridge is 63. The + & - button to adjustment temp. does not respond. I can hear that the both units are on. Its Maytag 12830910.
Posted by Cyril Caurthens on
Victor Mosim
    New Friend:
  • 95 Answers
You have a bad main control board if u push any button it’s just flashing u need to replace main board located on back side of the fridge
Posted on Oct 05, 2020
5 Related Answers
Anonymous
  • 237 Answers
SOURCE: Fridge fine, freezer not freezing
Weird scenario... the first thing I would do it to remove the interior back panel of the lower freezer section after the unit has been running for hours and check the coils to see the frost pattern on them. Should be even white frost all over the coils with no solid frozen coil (block-O-ice thing). Check the fan is running above the coils, etc. when. If everything is OK then you may have a control board problem. Let us know what you find in the freezer coil investigation and we can go from there.
Posted on Jan 15, 2007
Anonymous
  • 72 Answers
SOURCE: Freezer set at 0 degrees, but runs at 19 degrees. Ice Cream melting...
Low on freon/refrigerant maybe.
Posted on Mar 03, 2007
catriver
Ron Marek
  • 878 Answers
SOURCE: Kenmore trio 569. Fridge No getting cold Temp is now 81 degrees Freezer ice cold
Mark, check to see if the fan is running in the freezer section. Common problem on these 596's trios. If the fan is running, you might have a defrost problem. If it isn't, your part number for the motor is 67002778. No fan, no cool upstairs...Catriver..post back.
Posted on Mar 04, 2007
appldoctom
Thomas Malailua
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
James Chandler
  • 686 Answers
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Posted on Feb 17, 2009
My Viking professional refrigerator is stuck on 46 degrees refrigerator/ 6 degrees freezer. None of the buttons work. Is there a reset button?
press display on or (activate control) button first you should then be able to choose fridge or freezer and change set temp
after set will read actual temp 46 is a little high sounds like you have service issue
Jun 27, 2017 | Viking Refrigerators
Refrigerator
The self defrost mechanism is not working. The evaporator is getting blocked with ice, an insulator, and that affects freezer as well as refrig temps. When you unplug unit the ice melts and it will work till the ice block returns.
Sep 07, 2016 | Refrigerators
Fridge and freezer not cold. Ice melting.
Need to replace circulation fan in freezer,
Remove plastic bump out in the back of the freezer, to access fan...
Mar 02, 2015 | Kenmore Refrigerators
Why won't my refrigerator and freezer stay below 50 degrees?
Barbara, does it stay at 50 degrees even if you set it lower? I have a similar problem but temps. look ok.
Jul 30, 2014 | Maytag Refrigerators
Ice Melting towards the front of the ice hopper
Check that the fan motor wiring has not been disturbed. If the freezer fan is not working, the fridge will generally start cooling but due to poor air circulation , it will stay colder at the back but will get warmer at the front hence causing the ice to melt. The usual temp for a food compartment is around 4 degrees. The freezer should be -18 degrees celcius.
Nov 25, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
We have an stainless steel side by side Electrolux fridge and the freezer sise is fine but the fridge side keeps getting too warm reaching temps of 70 degrees...We adjust the temp settings and it sometimes...
On a side by side unit, the freezer actually cools the refrigerator side of the unit by the use of a "damper" door or switch. Check this between both doors for any ice blockage or damage and go from there. You might need to contact a professional to diagnose the entire unit if you don't "see" any issues.
Jul 21, 2012 | Electrolux Refrigerators
My refrigerator is not cooling everythings seems to be working fine and I can hear the flow of refrigerant but it is not getting cold. Is it possible that it needs more refrigerant
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Jul 10, 2011 | Dometic Refrigerators
My GE Profile Artica ice maker is making ice, but when I open my freezer, there are icicles from the ice compartment one the food below the ice maker and dripping down the inside of the freezer. The ice...
Hi!!
The Ice Maker and the Freezer/Fridge part of the unit work separate, that's why you get the ice made but the freezer can't keep it frozen.
Most likely the condenser, located in the back of the freezer is all frozen and covered with ice pluggin up the air ducts to the fridge, preventing it from cooling.
One quick solution will be unplugging the refrigerator and allowing it to defrost on it’s own or remove the freezer's back panel and using a heat gun or hair dryer to melt the ice, this will take about 20 to 30 min..
There are various reasons this type of problem:
The temp. controls are not set properly. Set controls according to manufacturer recomendation.
The small fan in the freezer is not working,
The defros timer is not working or,
The defrost heater coil is busted.
Once the ice is melted, plug unit back in and check for unit reactions. You should be able to hear the freezer fan working. Also, you'll hear about 4 to 6 times a day the defrost heater melting the ice in the back of the freezer, if NOT, check heater coil for continuity.
Don't forget to rate this post. Good Luck.
Jun 07, 2010 | GE Profile Arctica Stainless Steel Top...
My GE refrigerator GDS18LBPWW with freezer on bottom does not cool in the refrig. section. Yesterday, I pd $239 to have the Evaporator Fan motor replaced. The freezer is fine and back down to 26, but the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The ideal temp for the freezer is around 10 degrees F.
Look at the evaporator coils behind the rear cover inside the freezer and check the ice forming on the coils.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} . Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM
Dec 29, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
Our model is MCBR 415S. The top freezer acts as
You most likely have a bad thermostat control or a bad defrost timer.
Locate the defrost timer, probably inside the temp control panel.Defrost cycles should last 30 minutes then resume freezing.
Manually turn the timer control a 1/4 turn and see if it starts.
If so, replace the defrost control.
It could also be a bad temp control.
If the timer adjustment does not start the fridge. Tap the temp control. It may have stuck contacts.
Mar 10, 2009 | Magic Chef Refrigerators
Refrigerators Logo
14 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
