Question about Sony Audio Players & Recorders
Is there anyway possible to use a sony str d665 reciever only as a amplifier for my subwoofers not anything else
Posted by Wayne Lovelace on
Nathan Bush
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
I am also looking for the same query. Let me know when you find a solution.
Thanks
Posted on Oct 04, 2020
5 Related Answers
Anonymous
SOURCE: I NEED INSTRUCTIONS ON HOW TO CONNECT ALL COMPONENTS TO THE SONY STR-DE598 RECIEVER
codes for remote
Posted on Dec 23, 2007
ginko
Ginko
  • 19396 Answers
SOURCE: Sony STR-D665
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
Anonymous
  • 32 Answers
SOURCE: my reciever sony str-k740p reads (protect) and it
Grounded speaker wire check your lines going to the speakers
Posted on Jul 10, 2009
micromaster
micromaster
  • 3614 Answers
SOURCE: Require a users manual for :Sony-STR-KSL40-Dolby-Proligc-II-Ampli
go HERE
Posted on Sep 21, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Can't get subwoofer working with sony model STR-DE845 receiver
read the manual
http://www.retrevo.com/support/Sony-STR-DE845-Receivers-manual/id/387ci973/t/2/
First, it must be a self-powered subwoofer, then you've got some settings to select in the receiver.
Posted on Jan 21, 2011
How do i hook it up to a lcd tv with one digital output?
All of your vidoe components should run directly to TV via HDMI, component, etc., as input. Anything you hook to Tv can be watched using TV's menu, ie: TV, DVR< etc., of course, if you use component cables, you have to provide audio with other means. All you have to do then, is, run your digital optical out from TV to reciever. Use your TV menu to watch and you will only use the one input to reciever. Make sure you go through the recievers menu to make sure you have chosen the proper channel for listening, Vid2, Aux, etc.
Jun 18, 2011 | Sony STR-D665 Receiver
Can I connect a active subwoofer to my SONY STR-DE597 Powerful 6.1 channel AV Receiver
Yes, it only supports an Active Subwoofer. That's what the Sub Pre-Out is for.
Your sub will take that input, possibly split to two RCA connectors, and its internal amplifier will do the rest. Its own manual will give the specifics.
Feb 07, 2010 | Sony STR-DE597 Receiver
Trying to use a passive subwoofer with STR-DE445
The output of the Sony is "signal only" not power. Being "passive" like your sub. What you need is a sub amp, and they are not cheap, 400-600 on average "min". Unless you have a Velodyne 15 or 18, just get an amplified sub, they start around 150 new. Hope this helps
Mar 27, 2009 | Sony STR-DE445 Receiver
Sony-DG820 Subwoofer
The powered subwoofer should be connected to the black subwoofer output near the bottom of the receiver in just about the center. A subwoofer uses line level signals and has its own amplifier, Good chance that you wiped out a channel. Put the wiring back the way it was, and IF the channel was not directly connected to the speaker terminals, MAYBE, JUST MAYBE it will still work.
Chances are slim...
Apr 27, 2017 | Sony STR-DG820 Receiver
I have a STR-D665 FM-AM Reciever. It worked fine before I moved but now after about 5 minutes of play it will click and flash "Protect". Is there a way to reset this? Do I have something wired incorrectly?
When you moved did you put somethink on it so that it does not have good ventillation through itself to keep it from overheating? Or set it down in a way that it does not have ventilation room under it? Some papers set on top of it or a pillow under it would block good cooling ventilation through it.
Nov 28, 2008 | Sony STR-D665 Receiver
"Protect" flashing on STR-D665 Receiver
Check if you connect corectly the speakers wiresnand if they are right connected the audio amplifier Ic are damaged
No sound coming from subwoofer
sometimes these subwoofers are for builtin amplified subwoofers..so if this is the case it will not work
Oct 25, 2007 | Sony STR-DG510 Receiver
No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Dec 06, 2006 | Sony STR-D665 Receiver
16 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
